Home > Technical > LARINI EXHAUST for the TDV8 |
That's interesting. I suppose it's obvious when you think about it, but I didn't think the DPF would have that much of a muffling effect.
Fri Aug 01 2008 9:08am |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
it seems they also have varying effects on power - this is only anecdotal, however when the pdf was introduced on the Touareg (3.0 V6 tdi) owners who'd previously driven the 2.5tdi or pre-DPF 3.0V6 tdi indicated that the power was down |
Fri Aug 01 2008 9:13am |
I suppose that makes sense too.... the DPF must restrict the flow of the exhaust to some extent.
Fri Aug 01 2008 9:17am |
Ed Winchester Member Since: 09 Jan 2008 Location: Antwerp Posts: 15 |
Removing the final muffler is not bad idea actually, worth trying anyway.
Fri Aug 01 2008 10:21am |
gigv8 Member Since: 11 Jul 2008 Location: Rvenna Posts: 10 |
I'm just back from an exhaust workshop where I discussed my point with the mechanic.
Fri Aug 01 2008 4:33pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
He is correct on the diesel, don't know about petrol. They are purely to make it look good TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Fri Aug 01 2008 8:39pm |
Something to read... http://www.rrsport.co.uk/gallery/albums/us...%20DPF.pdf Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sun Aug 03 2008 2:35am |
Wow Sounds expensive if it goes wrong. Thanks Bobby
Sun Aug 03 2008 9:30am |
Had a look underneath my car and apart from the 2 cats and the DPF there are no silencers in my system.
Sun Aug 03 2008 5:11pm |
Michael, there are silencers in your system.
Sun Aug 03 2008 11:47pm |
Michael,
Mon Aug 04 2008 7:00am |
So now we know! Thanks Bobby 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Mon Aug 04 2008 7:16am |
Well done Bobby TDV6 - gone
Mon Aug 04 2008 9:03am |
Thanks Bobby.Had a look underneath my car again in the workshop(replacement of leaking manifold for second time) The JE system is connected to the DPF and runs al the way to the rear without any slincers in between,so there is no silencer no.8 as shown in the technical drawing. 2005 Range Rover Sport TDV6 HSE Java/Ebony(Gone) 2008 Range Rover Sport TDV8,Alaska/Alpaca,Stormers,JE Exhaust |
Wed Aug 06 2008 10:03am |
