Home > Technical > Knocks when turning the wheel?
sapkan
2006 Range Rover Sport Supercharged Java Black
Our 2006 S/C Sport has developed a knocking sound, it happens primarily when doing low speed maneuvers and turning the steering wheel. I tried using the search function but there has been so many issues with knocking and rattles coming from the front suspension area that I am plain confused. Has anybody had a similar problem? I am worried because I need to take a 600 km drive and don't know if it is safe to do it in the Range (dealer is at the far end of the 600km). There was a major car accident where I live about two days ago- a RRS veered off the road for no apparent reason killing all three passengers. It gave me the chills and made me think that a steering problem could have caused it.
btw our Range has been to the dealer for knocks from the suspension when going over bumps but I believe that was rectified by replacing some parts. That was 3-4 months ago and the Dynamic Response hasn't knocked since. 2006 Java Black S/C
Post #176611 Fri Jul 11 2008 5:55am
The knocking is probably the most reported issue on this site. There is no definite solution, although some of the solutions you have read about should at least be tried - they seem to work in the short term for some people.
As for your local RRS veering off the road and killing all three passengers.... that could have been for any number of non-mechanical reasons too, couldn't it? It's not a reason to stop driving yours Very Happy
Post #176628 Fri Jul 11 2008 8:04am
If you have the RRS in access height this happens. 2005 Zambezi TDV6 - Gone but not forgotten
Post #176632 Fri Jul 11 2008 8:12am
...you veer off the road and kill yourself? Confused
Post #176664 Fri Jul 11 2008 9:32am
Josh
Could be the Dynamic knock - no cure or could just be that the steering bumps need adjusting so that the wheels don't touch on full lock or your bushes need doing again.
Either way I doubt that it would cause the accident you are describing. That sounds like over zealous driving led to a departure from the highway. TDV6 - gone
TDV8 - gone
Post #176666 Fri Jul 11 2008 9:35am
No the knocking noise - numpty! 2005 Zambezi TDV6 - Gone but not forgotten
Post #176668 Fri Jul 11 2008 9:40am
sapkan
It doesn't happen in access only, it occurs in normal ride height too. Its not the steering bumps as it doesn't happen in full lock only but also when turning a little. Also the steering bumps were greased when I had the dynamic response knock rectified. It is more of popping (4-5 pops) than knocking sound, I have a feeling it is steering related but I am not 100% on this.
p.s. as for the accident a driver behind reported that the Range suddenly turned right and flew off the highway for no apparent reason...could be many things but still... 2006 Java Black S/C
Post #176678 Fri Jul 11 2008 10:01am
Josh
Sound like you will have to take the 600km drive to the Dealer. Or find one closer before you go. TDV6 - gone
TDV8 - gone
Post #176679 Fri Jul 11 2008 10:04am
pers1
Norway
I had the same problem and LR in Drammen change the front ball joints after this problem!
Just got it fixed 2 weeks ago! It seems to be fixed!
PerS RR SPORT TDv6 HSE 2007
Buckingham Blue
Ebony Interior
American Straight Grained Walnut
Dynamic Pack HSE
Rear Diff.
20 inch Stormer alloys
Privacy Glass
Premium ICE Pack
Hybrid TV
Personal Telephone Integration system
Tow Pack
Brembo Front Brakes
Bi Xenon Adaptive Head Lights
ADDED on delivery
Grille � perforated with "Titan" finish in buckingham bllue
Twin oval tailpipe finishers
Stormer side vents with "Crome finish"
Post #183009 Thu Aug 14 2008 7:35am
