Home > Technical > Rear door opening with LR button on keyfob
MX
United Kingdom 2008 Range Rover Sport TDV6 SE Java Black
When I collected the car I was able to release the tailgate with teh LR key - it was the preset option for both keys.
For some strange reason best known to itself it seems to have changed to only release the upper glass section now on both keys.
I can only imagine a fault in the door mechanism is causing it and cant see anything in the manual about how to configure it to release the tailgate anway ....
Does anyone know how to set this up from scratch ? I would like to reconfigure one remote to see if it works
Thanks
Mark RRS TDV6 SE Java Black +towpack +tintent +Permagrin
What a difference between this and my old Disco3
Formerly mxgeldar7
Post #175686 Mon Jul 07 2008 12:32pm
Jonny Fresh
Mine did exactly the same thing! New...it opened the tailgate, now it only opens the tailglass!!!
How peculiar!
Post #175696 Mon Jul 07 2008 1:23pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Aren't the instructions for the third button all in the manual? I seem to recall they are.
I just used mine for the lights, accidentally opening any of the tailgates was just plain annoying. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #175698 Mon Jul 07 2008 1:25pm
As Shmoogle would say... RTFM!
Press the third button on the key fob then keeping it pressed, press the lower boot button on the tailgate and hey presto, re-set.
Mine keeps resetting itself to upper part only too. Confused Runner up - 2009 Best Avatar Award Sad
Post #175702 Mon Jul 07 2008 2:06pm
MX
Sorry for that one chaps ..... I did read the manual and know how to do the lights and raise/lower suspension.......but must have missed the tailgate option. Will check again when I get home
Embarassed RRS TDV6 SE Java Black +towpack +tintent +Permagrin
Formerly mxgeldar7
Post #175718 Mon Jul 07 2008 3:10pm
MAW
I had exactly the same around a month ago !! Tried to figure how I could have unintentionally done it Rolling with laughter
Post #175734 Mon Jul 07 2008 3:37pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Mine keeps resetting itself from opening the tailgate to opening the tailglass too... have given up reprogramming it and just use the button to open the Tailgate now... bit disappointing to be honest!
Post #175834 Mon Jul 07 2008 10:39pm
mr boombastic
Australia
2nd Rower - I have a 08 TDV8 (purchased 12/07) and never realised that you could open the tailgate with the keyfob. Can't see it in the manual and was never told by the salesguy. It certainly is a feature that i would like to use but thought it was not available on Aussie spec Sports. Can you explain how to set?
Post #176024 Tue Jul 08 2008 12:16pm
Steve in germany
I think this happens when you share the car with the wife or you are using both sets of keys, i have found that when the wife has been out in the car with her key and then i get back in using my key the settings don't always revert back. Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #176027 Tue Jul 08 2008 12:28pm
Read my post above Rolling Eyes Wink Runner up - 2009 Best Avatar Award Sad
Post #176037 Tue Jul 08 2008 1:04pm
MAW
We share one key and the RRS still gets upset at times and loses it's mind Confused
Post #176077 Tue Jul 08 2008 7:43pm
2nd Rower
Thanks Steve, but I do not have a wife (i.e. don't share the car with anyone) and the second key is safely with all my other spare keys and never comes near the car on a day to day basis. It just resets itself!
Post #176101 Tue Jul 08 2008 10:08pm
2nd Rower
As ST explains above:
It is in the manual and it is standard on Aussie spec cars Thumbs Up
Post #176102 Tue Jul 08 2008 10:14pm
2nd Rower
My last UK car was a Boxster S and it had two buttons on the key fob in addition to the main lock / unlock functions. One opened the front boot and one opened the rear boot. Would be great if LR did a similar thing and had seperate buttons on the key fob for opening the tail gate and the tail glass. Idea
Then again, would prefer if LR actually gave us a tailgate like the FFRR!!!!! But that's another thread! Whistle
Post #176103 Tue Jul 08 2008 10:19pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
It can also can happen that there is a faulty catch - I hd mine stop opening the tailgate and I could not programme either key to operate the full tailgate. dealer fixed it, said there was a mechanical fault. RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #176270 Wed Jul 09 2008 8:31pm
