Home > Maintenance & Modifications > Removing Front Grill Badge?
xLusi0n
I'm trying to put the new black one one...how do I remove the green one or can I just stick the black one on the green?
Post #174593 Fri Jun 27 2008 5:48am
EX-X5!
get hairdryer. Heat up the badge. Next put a small self tapper into the existing badge, screw it in until it is in reasonably tight but obviously not gone through to the grill (!!!). Next heat it up more. The screw will help transfer heat to the back too! (good this isnt it).. Next, get some pliers, and start to pull on that little screw. Keep heating whilst you do this. You'll find it comes off a TREAT! Member I told you....... Thumbs Up
Post #174597 Fri Jun 27 2008 7:14am
xLusi0n
How deep is too deep?
Post #174761 Sun Jun 29 2008 7:54am
You can go all the way through then just unscrew till the screw is just hooked on to the badge not like you'll see the hold in the grill the new badge will cover that up! Thumbs Up RRS TDV6 Gone but still around
Post #174763 Sun Jun 29 2008 8:24am
