![]() | Home > General > TEMPERATURE SHUTDOWN |
Always worth trying the RRS equivalent of a reboot.... on the keyfob press lock, unlock, lock and unlock then start the engine. This is a reset process that you can use to clear down odd and unexpected problems... obviously if it recurs many more times then there's doubtless an issue which will require a trip to your friendly neighbourhood service department. |
