Home > General > TEMPERATURE SHUTDOWN
FA786
Need some help please , turned on my RRS the TV screen came up with error message "error temperature"...then the whole thing went off .No TV , Sat Nav, Audio/CD and everytime you try switch on the TV /Sat Nav or CD/Radio a message comes up in the green LCD display on the radio "Temperature Shutdown"...it seems that by the message that the complete audio/visual display and system has shutdown due to an overheat problem perhaps....any ideas anyone or has anyone experienced similar problems ....dealers have no clues as usual ..cheers guys
Post #172941 Mon Jun 16 2008 11:34am
Always worth trying the RRS equivalent of a reboot.... on the keyfob press lock, unlock, lock and unlock then start the engine. This is a reset process that you can use to clear down odd and unexpected problems... obviously if it recurs many more times then there's doubtless an issue which will require a trip to your friendly neighbourhood service department.
Post #172949 Mon Jun 16 2008 12:17pm
