Home > Technical > Squeaky front end
dukemasterpro
Australia
Squeaky front end
hi all-
Has anyone had a "squeaking noise" when for example driving over a speed hump or braking sharply whilst slowing down for a roundabout or similar?
Have Dynamic Response on a TDV8 with not many km's and little off road work.
I've just had a wash and polish and did not have the noise before so thinking that it's something needing a bit of grease or lube.
Is diagnosing a problem like this likely to be something that a dealer will charge like a wounded bull for or is it all part of the LR warranty.
Post #172241 Tue Jun 10 2008 9:06am
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Yeah, i had that. From memory it was worn bushes or something similar, and all covered under warranty
Mine was never there at the start of a journey, usually about 30 minutes in
Post #172259 Tue Jun 10 2008 12:04pm
NIM
Canada
Hi it is the front swap bar bushings HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
CONTACT ME .THANKS NIM
Post #172329 Tue Jun 10 2008 9:29pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
I too have had the dreaded squeak....turned out to be anti roll bar bushes and a loose Shocked anti roll bar!!
Has been sorted now, but still knocking - which is a Censored joke after 5 attempts Big Cry Big Cry L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #172333 Tue Jun 10 2008 9:56pm
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
I had the same on my old 07 model. Had some anti-roll-bar bushes made special with an internal diameter 0.004" smaller than standard- (tighter fit) I had them made with slots in the centre of the bush and filled them with vaseline to lubricate the anti-roll-bar as it moved sideways. Instant cure. It was a system I designed in 1983 on the early XR3i with the same problem.
Easy way to prove if it is that is slack the brackets off to release the bush and squirt some spray lube inbetween the bush and roll bar and try it. Because sometimes its the lower suspension arm rear bushes that squeak. You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #172608 Fri Jun 13 2008 7:14am
dukemasterpro
Australia
WORN BUSHES
Finally booked in for a checkup of the squeaking which turned out to be worn front bushes, fixed under warranty!
No charge and good service from the dealer with regards to dropping off the car, being kept informed and pleasant service.
Just hope they last longer than 7000km's.[/u]
Post #178012 Thu Jul 17 2008 11:55am
Glad it's sorted now Thumbs Up
Care to name the dealer who looked after you so well? Very Happy Runner up - 2009 Best Avatar Award Sad
Post #178042 Thu Jul 17 2008 12:51pm
dukemasterpro
Australia
Trivett Classic In Sydney - must say the whole process was good from drop off at the valet style service department, straight on a shuttle bus back into the CBD and a quick wash and vac at the same time for collection. They were not the supplying dealer either as I had bought from a Melbourne dealer through a fleet buyer.
Post #178358 Fri Jul 18 2008 9:53am
Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #178361 Fri Jul 18 2008 10:20am
