Home > Maintenance & Modifications > [FAQ] DIY Trailer Light Hookup |
AlanM Member Since: 20 Feb 2007 Location: Victoria BC Posts: 88 |
Note that as in my first post, you cannot just hook up trailer lights to the rear light cluster.
Wed Feb 28 2007 12:00am |
Spurred into action by the idiot above, I got to looking at the problem more intensively. The twit just mentioned hooked up his trailer lights by splicing into the wires just behind the rear lights. Tut, tut this will not do it. LR have already wired up a nice pair of sockets for trailer wires and all you have to do is find these two sockets, determine which terminals operate which rear lights and plug into them.
Wed Feb 28 2007 4:39am |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
Alan - respect is definetely due |
Wed Feb 28 2007 10:27am |
Alan, you're a marvel with these things. Excellent stuff!!
Wed Feb 28 2007 2:43pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Good stuff mate RRS TDV6 Gone but still around
Wed Feb 28 2007 3:32pm |
Hey - I got another sticky !
Thu Mar 01 2007 4:54am |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
Has anyone had problems with "flashing" indicators?
Tue Jan 01 2008 7:50pm |
xLusi0n Member Since: 12 Jun 2007 Location: Los Angeles Posts: 92 |
I just saw this thread after I installed my OEM wiring HAHA, sucks. But, it was only 150 USD for me. And I guess I don't mind that for a clean install.
Thu Jun 05 2008 11:53pm |
Above all check you have a very good earth connection; funny things will happen to indicators, brake lights etc otherwise. |
Thu Jan 06 2011 5:58pm |
livefreeordie999 Member Since: 10 Nov 2015 Location: Coleraine Posts: 4 |
Hi, i have just tried this diy approach with using a bulb tester to find out which pins power what. I am using a standard 7 pin socket but i can only get one sidelight to work on trailer board?? Also if i brake the when i am indicating the indicators go off?
Thu Feb 11 2016 6:00pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
Connect the trailer L and R Side lights (black & brown) to the same RRS wire. This is what the factory kit does.
Thu Mar 31 2016 11:58am |
You need a decent load on the trailer indicator. I tried a 5W bulb and the car wouldn't detect it. I find 21W bulbs work best |
Thu Mar 31 2016 12:03pm |
Wed Sep 26 2018 11:03am |
gstuart Member Since: 12 Nov 2017 Location: kent Posts: 3 |
Hi
Wed Sep 26 2018 12:14pm |
