![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
NIM Member Since: 02 May 2008 Location: TORONTO Posts: 7 ![]() ![]() |
COULD YOU GUYS GET YOUR DEALERS TO REPLACE THE BUSHINGS ON THE ARC UNIT THEY ARE JUST LIKE THE SWAY BAR BUSHINGS , I HAVE HAD A LOT OF RR SPORT WITH THIS FAULT, AND ALSO LET THEM REPLACE THE NUTS ON THE SWAY BAR LINKS AND MAKE SURE THEY ARE TORQUE TO 75 FT LBS, I HAVE HEARD THE NOISE AND THIS SEEMS TO FIX IT THANKS NIM. HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
chris Member Since: 27 Aug 2006 Location: south Posts: 37 ![]() ![]() ![]() |
Hi Nim,
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
I haven't had the DR knocking on this one nor the last one thankfully. Removal of fuse made no difference to the rattle. It was definately the AR bushes and lower ball joint causing the problems. I also had the rear AR bushes replaced 2 weeks ago as well. So now that it's nearly 10 months old the silence is finally bliss ![]() ![]() ![]() TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Hi guys, another fault is that i saw a mechanic work on a vehicle for 2 weeks and when i got the rr sport i figured that the line was not spaced in the mounts properly, and it was causing the noise, if your dealer activate the arc system it will make the noise in the shop and they will be able to better diag the problem.Thanks Nim. HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
weim71 Member Since: 07 May 2008 Location: Scotland Posts: 17 ![]() ![]() ![]() |
Hi Guys,
Definitely not normal, as the countless posts on here will confirm. The fact that it's "normal" seems to be a LR party line. |
Unbelievably, my stealer is on his 4th attempt at rectification (slightly dirty word |
Car got recovered yesterday on LR assistance advice.......suspension was making a hell of a noise. It sounded like something had worked loose on top of the normal knockety knock noise!!! |
Oh jesus thats awful!
I think that's the issue........LR don't seem concerned or are loathed to get involved in any of the situations. The dealers seem to be the ones trying to find the resolution, but there is no definitive......it is absolutely crazy and pitiful to think that as much as we are now celebrating the RRS 3rd birthday - this |
plum Member Since: 16 Sep 2007 Location: Heptonstall Posts: 39 ![]() ![]() ![]() |
Just for the record, mine is too, been back 6 times to 3 different dealers. ![]() ![]() ![]() |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Car returned and all is well again. Apparently the 75Nm torque setting as discussed here previously, worked itself loose |
Well, i hope that has fixed it and there's no more knocking. This sort of thing |
