Home > Technical > Minimum Tyre Pressures for Off-Road - Sand Dune |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
Well either this weekend or next we are off to Stockton beach to test out the Sand Dune capability of the Sport. The beach runs for about 35K's and is a favourite 4x4 spot at weekends, http://www.openroad.com.au/travel_4wd_daysonstocktonbeach.asp
Fri May 09 2008 8:59am |
Thank god for the D3 site , got an answer within 10 minutes.. Another Pommie Bar Steward down under
Fri May 09 2008 10:54am |
Try asking them about boobies though and they'd be stumped!
Fri May 09 2008 12:38pm |
like these you mean Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Fri May 09 2008 11:15pm |
tastech Member Since: 20 Nov 2007 Location: sydney, australia Posts: 94 |
HI Zilch What was the answer?? for the tyre pressure?? Steve |
Sat May 10 2008 12:31am |
Steve a number of people on D3 stated i should be okay down to 16 PSI, thought that might be a bit low for the standard tyres, so will see next weekend, need to get a few more bits in the week (staun deflators, Compressor extension cables etc), tried getting the Stauns today but no luck. Cheers Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Sat May 10 2008 7:33am |
Jim, thanks.. Pardon my ignorance, what are staun deflators...i assume they are some sort of device for letting out air??? My beast should be here next week, finally ...so i will soon be in the active club...so am starting buy some gear... |
Sat May 10 2008 11:10am |
Steve, Spot on, you can set them to a predefined pressure and they will release the air until it reaches the desired PSI, not an exact science so sometimes you have to use the compressor to re-adjust slightly
Let me know when it arrives, and if you want to meet up for an off-road drive, just give us a buzz on here. Stockton would be better with 2, one for recovery Cheers Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Sat May 10 2008 11:31am |
Thanks Jim....will let you know when it is here... Where would you recommend i shop for some recovery gear? ARB?? I was just going to buy a kit? and what about compressor? ..sorry about all the questions... thanks |
Sun May 11 2008 1:34am |
Steve depend where you live, i am not far from Mannell Motors or the Hornsby 4x4 megastore, so will pop round there, they do a lot of ARB stuff. My kit currently consists of Snatch Strap, Shovel, Tyre Gauge, Air Compressor and not a whole lot more. I was planning to get a metal base plate for the jack, some matting to shove under the wheels if it gets bogged down. Before the weekend i will get the Staun deflators, a new Air compressor due the fact the one i got from Supercheap Auto keeps blowing a fuse and will not run for more than 10 seconds, I did rewire it from croc clips to 12v outlet plug but even back on the clips it blows after a very short time I am hoping to get to Stockton this weekend come what may It might be worth posting on the D3 site and let them know what you will be mostly up to in off-road terms, or see the Duke Master Pro post in the D3 ANZ section. Good luck with the car, remember to post some pictures on here cheers Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre Last edited by Zilch on Mon May 12 2008 10:53am. Edited 1 time in total |
Mon May 12 2008 9:18am |
Thanks Jim,
Mon May 12 2008 9:27am |
Steve, Not sure what compressor, will do a search. One with a longer cable the current one if it clips to the battery it cannot reach the offside rear wheel I will ask around the 4x4 shops to see what is best, but if it as a 12v connector, the max rating is 15 amps according to the fusebox. Cheers Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Mon May 12 2008 10:43am |
As you mentiond Anthony, the firmer the sand the less you have to drop, however Stockton is notorious (or so i have read on some of the Aussie 4x4 forums) for being quite soft in places, in particular around the south end of the beach and dunes, hence why they recommend that pressures are dropped prior to driving on Lavis Lane on the South entrance [quote="redrover"If it was me I would start at around 20psi and see how you go. I look forward to hearing your experiences and trying it myself some day[/quote] Agree, i was going to drop it to about 18 psi and see what happens. Let me know when you fancy a run out, and assuming there are no major mishaps this weekend, then i will be no doubt more than ready for another trip across Stockton. Perhaps we could arrange a RR SPORT Aus section trip up there Cheers JIm Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Mon May 12 2008 10:51am |
Tastetech (got a first name)/Anthony, i put the tyres down to 18 PSI and not a problem on the sand, i would recommend the Staun deflators, they make letting the pressure down so simple and automatically cut off at the correct pressure (or thereabouts)
Sun May 18 2008 7:56am |
