Home > Technical > Minimum Tyre Pressures for Off-Road - Sand Dune
tastech
Australia 2008 Range Rover Sport TDV6 SE Rimini Red
Zilch wrote:
Tastetech (got a first name)/Anthony, i put the tyres down to 18 PSI and not a problem on the sand, i would recommend the Staun deflators, they make letting the pressure down so simple and automatically cut off at the correct pressure (or thereabouts)
Jim
Jim
Where did you end up getting those stauns from? and what was the cost?
cheers
Steve Toyota Corolla...Sad((((
formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse
Post #170081 Mon May 19 2008 1:36pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
tastech wrote:
Jim
cheers
Steve
Steve i got them from 4x4 Megastore near Hornsby, i believe any reputable 4x4 shop will sell them. Cost $79 for a set of 4. To be honest 1 or 2 will do it, as i only let 1 tyre down at a time so i could check the tyre pressures and not have to wholesale re-inflate the lot of them. Even managed to get the supercheap auto compressor working again, in the end i did not require the compressor at Stockton, there are service stations within 300 metres at each end of the beach with Air facilities Thumbs Up Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #170158 Tue May 20 2008 10:53am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I'm about to order myself some too:
http://www.4x4store.com.au/Staun-Tyre-Deflators-pr-14441.html
Post #170159 Tue May 20 2008 11:04am
Zilch
those be the ones, deflated to approx 18-20 psi on preset, worked a treat Another Pommie Bar Steward down under
Post #170160 Tue May 20 2008 11:19am
