![]() | Home > Technical > Exhaust Tips - knocking |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
Make sure you have them on as snug as possible, you should have the down pipe of the original exhaust coming through flush with the exit oval of the new chrome end, just losen the grub screws and see if they move a little more in, hope these pics help
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
I just noticed the one that is knocking is jutting out a little bit more than the one that isn't - so like you said I need to push it back a little bit more......to be on the safe side I got some stick on pads to either put on the pipe or the balance.....to cushion any blow - as the new pipe does not get hot at all, I think they will stick on....and stop the vibration....but of course will try to push it back first and see if thats works...thanks mate |
Your very welcome, hope it's sorted now |
Steve any pic's of car from the back? RRS TDV6 Gone but still around
Here you go
Oh and this one
Nice |
yes it's all fixed now - took it off again and pushed it back as far as it would go - but also added little cushion stick on pads to some parts near the balances and also on the top side of the tip where it nears the underside of the rear bumper (just in case!) and it works wonderfully, and no rattles or sounds at all - at idle or at speed!!! Thanks Steve for your pics and help. Where in germany are you? Mrs Nick and I spend a lot of time in Hamburg with work. |
Steve how come your car is on a Scottish registration plate, did you buy from a Scottish dealer? All S's and T's are Scottish registered cars. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tim, thanks again for sorting the meet in London for later in the year - looking forward to catching up with you. |
MMM, it's to do with the wife, well her job actualy, because she is GI jane (steady Jay) we have to use the British Forces Germany plates over here, it just so happens that they are currently having a run on Scottish numbers at the moment, I think SN is a perth prefix. Speed Limits! not where I live!
we are 10KM from Paderborn, which is roughly 1 hour from Dortmund or about the same from Hannover Speed Limits! not where I live!
Like Germany but can't get used to everywhere being closed on Sundays!
Yep those chrome tips do make the car look good, i think it could be standard on factory cars as it does not effect the route of the exhaust gasses Speed Limits! not where I live!
