![]() | Home > Maintenance & Modifications > GPS AERIAL |
mr boombastic Member Since: 08 Dec 2007 Location: NSW Posts: 40 ![]() ![]() |
I have also ordered the dummy aerial from ebay, but it has not arrived as yet. I emailed the supplier about how to remove the blanking plate and they told me that it is held on with bolt/s. You have to remove the roof lining to unscrew the bolt/s. I had a look at it recently and decided that the best section to peel away was from the back (open the boot). If you push aside the rubber moulding you can gently peel back the roof lining, you will hear a couple of clips unclipping. Once the lining has been peeled back you can see the bolts holding the blanking plate (thats as far as i have gotten). It looks like it could be a little fiddly getting at the bolts - maybe a 2 person job as someone may have to hold the roof lining whilst unscrewing. Don't know yet as i have not recieved mine. Hope this helps - cheers!
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
Are'nt you guys concered about how water tight this mod will be? Think you may be buying into trouble here. Speed Limits! not where I live!
Yes the thought had crossed my mind. Will see when i receive article & see what it looks like. |
Yes, you guys should be! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
I have not seen any RRS with a blanking plate in place of the antenna.
Did you guys fit this in the end? Speed Limits! not where I live!
I bought one through the local dealer when I had the TDv6 and got them to fit it........................ I was very glad that I did because it took a couple of visits back to the workshop to get it completely watertight. In very heavy rain I got a damp spot on the roofliner and when the car was left standing for a while there was a little puddle on the roller blind boot cover. I suspect that they sealed it with silicone sealant on the inside, but it cured the leak. Fitting and repairing the leak required removal of the headlining too................................ not a job to do by yourself. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I have just received mine and i am still deciding whether to fit or not. I definitely will not remove blanking plate and place over holes as i am not confident that it will be water tight as it is hollow. There are numerous bundles of wires hanging at the rear of car roof and it probably is not worth the risk to do it this way. I was thinking of trimming the sides of the blanking plate and then screwing it back on roof and then placing the aerial on top of this. What do you think of this? My other option is to purchase a genuine aerial and screw this on. |
No news from Philip so far, Steve. I even sent him a PM (in response to a PM he sent me earlier) but no reply. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sure he will be back soon! Speed Limits! not where I live!
Inshallah! And may his problems be solved! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
