Home > Maintenance & Modifications > GPS AERIAL
philipmd
2007 Range Rover Sport TDV6 HSE Zambezi Silver
GPS AERIAL
Hi.
I bought the GPS aerial from EBAY.
Would you know how to remove the existing blanking plate off the roof of the range rover sport, so I can glue the aerial?
Thanks.
Post #156910 Sat Feb 23 2008 8:25pm
mr boombastic
Australia
I have also ordered the dummy aerial from ebay, but it has not arrived as yet. I emailed the supplier about how to remove the blanking plate and they told me that it is held on with bolt/s. You have to remove the roof lining to unscrew the bolt/s. I had a look at it recently and decided that the best section to peel away was from the back (open the boot). If you push aside the rubber moulding you can gently peel back the roof lining, you will hear a couple of clips unclipping. Once the lining has been peeled back you can see the bolts holding the blanking plate (thats as far as i have gotten). It looks like it could be a little fiddly getting at the bolts - maybe a 2 person job as someone may have to hold the roof lining whilst unscrewing. Don't know yet as i have not recieved mine. Hope this helps - cheers!
P.S. Tell me how you went.
Post #156927 Sun Feb 24 2008 3:28am
Steve in germany
Are'nt you guys concered about how water tight this mod will be? Think you may be buying into trouble here. Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #156936 Sun Feb 24 2008 10:32am
mr boombastic
Australia
Yes the thought had crossed my mind. Will see when i receive article & see what it looks like.
Post #156939 Sun Feb 24 2008 11:13am
Bobby
Yes, you guys should be! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #156940 Sun Feb 24 2008 11:15am
Bobby
I have not seen any RRS with a blanking plate in place of the antenna.
However, this will help you gain access to the mounting of the antenna if you had one and hopefully you could see if the blanking plate is also fitted the same way...
http://www.rrsport.co.uk/gallery/albums/us...na%202.pdf Malaysia Boleh!
Post #156993 Mon Feb 25 2008 12:22am
Steve in germany
Did you guys fit this in the end? Speed Limits! not where I live!
Back in a D3
Post #157783 Sun Mar 02 2008 10:12am
Tim in Scotland
I bought one through the local dealer when I had the TDv6 and got them to fit it........................ I was very glad that I did because it took a couple of visits back to the workshop to get it completely watertight. In very heavy rain I got a damp spot on the roofliner and when the car was left standing for a while there was a little puddle on the roller blind boot cover. I suspect that they sealed it with silicone sealant on the inside, but it cured the leak. Fitting and repairing the leak required removal of the headlining too................................ not a job to do by yourself. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #157785 Sun Mar 02 2008 10:31am
mr boombastic
Australia
I have just received mine and i am still deciding whether to fit or not. I definitely will not remove blanking plate and place over holes as i am not confident that it will be water tight as it is hollow. There are numerous bundles of wires hanging at the rear of car roof and it probably is not worth the risk to do it this way. I was thinking of trimming the sides of the blanking plate and then screwing it back on roof and then placing the aerial on top of this. What do you think of this? My other option is to purchase a genuine aerial and screw this on.
Post #157789 Sun Mar 02 2008 10:52am
Bobby
No news from Philip so far, Steve.
I even sent him a PM (in response to a PM he sent me earlier) but no reply. Crying or Very sad Malaysia Boleh!
Post #157868 Sun Mar 02 2008 10:50pm
Steve in germany
Sure he will be back soon! Speed Limits! not where I live!
Back in a D3
Post #157887 Mon Mar 03 2008 9:23am
Bobby
Inshallah!
And may his problems be solved! Malaysia Boleh!
Post #157897 Mon Mar 03 2008 11:02am
