![]() | Home > Maintenance & Modifications > Hi newcomer here!....got a question about side steps... |
mambo Member Since: 24 Oct 2007 Location: in the mud Posts: 44 ![]() |
Side steps can be taken off without any problem, some trim needs to be cut to install mudflaps so they may leave a mark. |
AJ Member Since: 20 Nov 2007 Location: London Posts: 8 ![]() |
has anyone else removed these....are any marks visable? is there any chance for water leakage?
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Welcome, AJ. A 4-5" section of rubber moulding around the front wheel arch is cut to get the front mud flaps to fit flush with the body and to screw them on. So, there will be a couple of screw holes left exposed where the rubber moulding used to be after you remove the flaps, no biggie. Here is a picture of mine after I removed the front flaps, you can see the two holes... I had to remove them when I installed my rock sliders, but I have since put them back on after a bit of creative "cutting" of the flaps around the sliders (I couldn't find a close-up shot, sorry):
Thanks for the informative reply....i think i will get the trim/moulding replaced if the situaution arrises and its good to know that i can take off the steps and then put them back on if i change my mind.
Not sure if its been said before 'white is the new black!' 2005 Zambezi TDV6 - Gone but not forgotten
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Not sure if it's been said before 'ONLY LR OE STEPS WILL DO!' Runner up - 2009 Best Avatar Award |
I don't know it has SuperT? RRS TDV6 Gone but still around
Let me try again |
