![]() | Home > Technical > Front Parking Aid - advice requested please |
Or you could be close to the side wall of your garage. 2005 Zambezi TDV6 - Gone but not forgotten
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
my parking sensor used to give the solid sound too
CA-SPORT Member Since: 08 Feb 2008 Location: San Francisco Posts: 14 ![]() ![]() ![]() |
Indeed, thank you for the tip. I did "test" this possibility with the aid of another person having them walk around the perimeter of the vehicle while the sensors were activated. I also parked between 2 vehicles to test as well. It appears to not be the issue.... The wetness possibility mentioned by npinks is something I've not considered as I did wash the vehicle Saturday and experienced this issue the same day. Hmmmmmmm ![]() Thank you! '10 RRS '09 XF '07 MC '06 VW ![]() |
SteveWilliams Member Since: 05 Aug 2007 Location: Swindon Posts: 138 ![]() ![]() ![]() |
I find them over sensitive when parking. Better over sensitive than bumps though |
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 ![]() ![]() ![]() |
Do you have an incline as you pull into your garage? Isn't there a sensor under the car that let's you know when you are close to 'grounding out'?
Yes, but not connected to the PDC sensors I don't think.
My garage is not on any kind of slope - very level. However there is my furnace/water heater unit and there is some metal trim peices on/around several architectual details such as the doors, etc. There is also large exposed ventilation pipes for the forced-air heating but those are above the hieght of the vehicle? Hmmmmmmm..... ![]() '09 XF '07 MC '06 VW ![]() |
