Home > General > Pre-heater
Page 5 of 5 <12345
Tim any news about the pre heater? 2005 Zambezi TDV6 - Gone but not forgotten
Post #20597 Sat Mar 25 2006 7:03pm
Tim in Scotland
Silence was the reply................... emailed LRADVICE addy that you posted and they too are conspicuous by their silence! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #20599 Sat Mar 25 2006 7:06pm
csoky
Hungary 2007 Range Rover Sport TDV6 HSE Zermatt Silver
I bought my car one month ago.
The FBH did work. ( I saw it. )
But the last few days the water is warming up so slow and I checked
the FBH, it doesn't work. The temp is under the 5C.
Who has any idea about this?
Is it out of order? So quick!
Post #156249 Mon Feb 18 2008 10:04pm
rrsjo
I'm not 100% sure but I think you have to have the heater switched on for the FBH to work - even if the outside temperature is below 5 deg C. Try it. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #156252 Mon Feb 18 2008 10:25pm
csoky
Ok! I will check.
And my other idea, I will filling up my tank, because the level is low now. Question
THX
Post #156262 Mon Feb 18 2008 11:16pm
flydive
csoky wrote:
Ok! I will check.
THX
Yes, it won't start if you have low fuel warning '08 RRS TDV8
Post #156287 Tue Feb 19 2008 8:49am
PH1
I've got one on my TDV8.
Is it meant to make a high pitched squeal once the engine has been turned off? I just moved the car down the driveway so the engine was only running for about 2 mins, once the engine was off I can hear a high pitched squeal, opened the bonnet and the noise is definately coming from the pre heater. Is this normal?
Post #156307 Tue Feb 19 2008 9:54am
Can't comment on the RRS doing it, but the FL has always done it.
Post #156308 Tue Feb 19 2008 9:58am
csoky
csoky wrote:
Ok! I will check.
THX
Yes! That was the problem Very Happy
Post #156391 Tue Feb 19 2008 9:20pm
Japseroony
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hi, I think I have one on my TDV8 but the pipework is different - they say mine is an 08 model. So far I have not asked Stratstones about it but she takes an age to warm up and yesterday and the day before it was
-6 degrees so not sure if this thing is connected or not Exclamation "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #156835 Fri Feb 22 2008 4:21pm
Page 5 of 5 <12345
