![]() | Home > General > Pre-heater |
Ha |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
That is the good side! |
This whole pre-heater thing is very odd! I'm taking the line that my car does not start well in cold weather and there must be a fix = pre-heater. I WANT ONE! 2005 Zambezi TDV6 - Gone but not forgotten
I understand why the pre-heater's meant to be there and why it's a Good Thing but I'm not sure I gather why it helps with cold starting, if you can't set a timer on it to come on before you actually go to start the car in the morning.... |
_simon_ Member Since: 17 Mar 2006 Location: Shropshire Posts: 40 ![]() ![]() |
It doesn't help with cold starting... helps bring the engine up to temperature far more quickly - thus allowing the cabin to warm up faster too.
So the fact that my RRS takes ages to heat up in the cabin area could be down to a lack of a pre-heater. Do the latest software upgrades sort this out and how? 2005 Zambezi TDV6 - Gone but not forgotten
I think there's some changes to the way the blending works in a newer s/w release... I'm sure I've read some folks on here have had it and their heater performance has improved. I'm like you VA.... takes ages for the car to get warm and I've tried everything. It's not been so bad past few mornings as the ambient temp hasn't been too low... |
this probably due to the lack of an FBH in VA's case... the blending change was to avoid FBH fumes and also to stop cold air from the face vents when the temp dial is set to warm you up.
JASON Member Since: 24 Aug 2005 Location: GLASGOW Posts: 46 ![]() ![]() ![]() |
I have one. I did wonder why there were fumes from the front occasionally. I also recognised it from its picture as before I wondered what the box was. Thank you for enlightening me |
looks different than the D3 one... slightly smaller in the pic or maybe situated differently.
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
I've had this software upgrade. It does make a small improvement to the speed the heater warms up, but more importantly it makes a huge difference in the way the climate control works - it now works properly - not more setting it to maximum to get any heat - I've never put it above 20deg since and it is actually hot!! Matt ------------------------------------------- RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance! |
OK then, managed to find out a little bit of info about the FBH tonight.
