![]() | Home > Technical > Nokia 6230i |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
I have a 6230i running on bluetooth and don't have a problem. The car is an MY08 and therefore still wired for the hand set under the arm rest but with the factory OE bluetooth as well.
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Like RRSJO I have an 08 with both wired and bluetooth connections, I find the bluetooth works better with the 6230i Sons of dogs come hither and get flesh
Don't forget that on older models where you are using the cradle, the actual phone calls are still transmitted between the phone and car via bluetooth. The cradle was only ever for charging, phonebook sync and connection to the fin aerial. The advice of the volume having to be below 20 is true though... I had to set phone calls to 18/19 if I remember right. |
When using the cradle my phone starts off with a low volume level and have to turn it up to about 25 to be able to hear it, then after about 20-30sec the volume jumps up, then I have to turn it down to about 18 or I get the above problems. When using Bluetooth the volume is about 17/18 and never have to adjust it. @ shmoogle How can it transfer by Bluetooth when the Bluetooth on the phone is switched off? Sons of dogs come hither and get flesh Clan Cameron |
Guess it's all done buy the cradle then and no BT RRS TDV6 Gone but still around
Yeah, I suppose so... As had been discussed here before, I was always under the impression that you always had to pair it to the car via BT irrespective of cradle, but if it works with BT turned off on the phone, then like Jay says, must have all gone via the cradle. |
It has to be as then the phone is plugged in you can get more info off it then BT and plus phonebook over BT just came out on the MY08??? RRS TDV6 Gone but still around
Yeah, phonebook sync was always over the cradle mate... until recently of course, but I thought that BT ws still used for the call even though you were connected to the cradle. |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 ![]() ![]() |
You can have a 6230i in the cradle with Bluetooth switched off.
But if you had it plugged into the cradle, you would get phonebook sync and therefore not have to wonder who's number it was.... you're right though, at least they forced the BT hand now by allowing wireless sync and even getting rid of the cradle interface on 08.5 |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
Trouble is when BT connected the battery lasts next to no time. I have a 6230i in my D3 using a cradle, my E50 is diverted to it. My wife's Fl2 has the MY08.5 phone book, but needs to constantly charge her phone, so ends up with ugly wires in the car, you don't get such good coverage as having the external aerial either. Porsche Cayenne S Diesel 66 Plate |
on an aside, Tesco here in Wick are selling off 6230i phones for £50 Sons of dogs come hither and get flesh
They still sell 6230is in Wick! |
Yeah that’s exactly why I’m reluctant to give up my 6230i
But that way the ring volume is rubbish ![]() There's just no keeping me happy is there ![]() Grumpy old man that I am ![]() |
