Home > General > Range 0 miles |
About 50 metres! How sad is this - I was trying to get it down to zero, the petrol station sits betwen 2 roundabouts 100 metres apart, I went round these 2 rounabouts about 10 times until the zero popped up! 2005 Zambezi TDV6 - Gone but not forgotten
Fri Mar 03 2006 9:19am |
Fri Mar 03 2006 9:21am |
I do it all for the purpose of research! 2005 Zambezi TDV6 - Gone but not forgotten
Fri Mar 03 2006 9:22am |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
And here was me thinking you had spotted Robin Sunpower sitting between the 2 roundabouts doing a 4x4 survey - must have confused him - HHhmmm thats the 10th silver RR sport in the last 5 minutes
Fri Mar 03 2006 10:39am |
Invictus Member Since: 12 Jan 2007 Location: Atlanta, Georgia Posts: 30 |
I hit 0 miles on my first road trip! I was terrified... I did this for about 2 miles. I hope to never do this again!!! |
Tue Feb 20 2007 3:05am |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
I noticed that not only u run down to zero fuel, but the outside temperature was also zero degree how u made it 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver SOLD-V8 Defender 90 |
Tue Feb 20 2007 6:30am |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
did it on the way back from Merc World - after turning the engine off in a queue, when I restarted it the mileage jumped back up to 12miles (or similar) remaining
Tue Feb 20 2007 7:17am |
No fuel and freezing cold... mind you, at least there was a Sainsbury's at VA's two roundabouts to provide sustenance!
Tue Feb 20 2007 9:21am |
TonyMeg Member Since: 10 Feb 2007 Location: North East Posts: 128 |
Be careful running your motors down to zero miles .. It drags all the crap through the lines out of your tank & clogs up injectors, can cause a whole load of grief. Theres usually around 10 liters left in the tank when the miles show Zero too |
Tue Feb 20 2007 10:48am |
I understood this is now not the case due to improved fuel filtering at the tank - but I may be wrong |
Tue Feb 20 2007 10:54am |
It would there for clog up your filters & if the filters are anything like the ones on a merc from the tank there a B d to change |
Tue Feb 20 2007 10:56am |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
I'm sure you're right Tony, cant do it any good running that low. I dont go below 1/4 tank, or fill up.., plus Redex every tankful! |
Tue Feb 20 2007 7:04pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
It all depends on where the pick up pipe is situated in the tank, chances are you will never drain the tank bone dry as the pipe probably doesnt go right to the bottom.
Tue Feb 20 2007 7:16pm |
You know it makes sense! |
Tue Feb 20 2007 8:46pm |
