![]() | Home > Technical > Lop-Sided TDV8 and Key Memory Issues |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
Hi
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Definately sounds like a faulty ride hight sensor to me.
PLidds Member Since: 23 Jul 2007 Location: Germany Posts: 27 ![]() ![]() |
TB - Thanks for this; my local dealer is German and they probably don't get the throughput of issues to buid-up a good knowledge base so I'm just trying to get some responses to be able to point them in the right direction on my second visit. RRS TDV8 Java/Ebony, Privacy New Model 07 Mini Cooper S Blue with white stripes Debating RRS TDV8 in Stornaway or Jag XF SV8? |
Good luck in resolving the fault with your moter.
PLidds, there was a bulletin on this early this year...
Bobby - thanks for this; the attached bulletin seems to cover the exact problem. Will print-out and take to dealer om Monday. Anybody got any info on the key issue? Thanks, PL RRS TDV8 Java/Ebony, Privacy New Model 07 Mini Cooper S Blue with white stripes Debating RRS TDV8 in Stornaway or Jag XF SV8? |
As Kaine said just a sensor problem
As for you key settings check that your car battery is OK if not that get them to check your ECU. 2005 Zambezi TDV6 - Gone but not forgotten
PLidds, any luck with the 'Lop-Sided' issue? Malaysia Boleh!
Must be fixed and now he can't pull himself away from the car to come back and tell us! |
![]() ![]() For his sake, I hope so. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sorry all; been away working for the week for a change. Not had time to check-in. Picked the car up this morning from the local stealer and as predicted by you clever folk it was a sensor issue this time. Wonder how long this will last until it starts to list again. Is this generally a recuring problem?
Been down the autobahn and now the rear left brakes are sticking. Stank and was extremely hot when I got back and the excess brake dust also gave things away. Tried applying and releasing handbrake a number of times but still seems to drag significantly. Another trip back to the dealer needed. Also Sat Nav brigthness is always dull now even with lights off and limbar control has fell off seat. I'm sure all will be sorted one day. RRS TDV8 Java/Ebony, Privacy
