Home > Technical > Lop-Sided TDV8 and Key Memory Issues
PLidds
Currently seem to have an issue with the rear left suspension being much much lower that the rear right when parked on level ground. Front end seems fine. Been through the threads but cannot find a specific answer for this.
On parking only the rear left suspensions seems to deflate and the cars sits lop-sided. This lean is signifcant and the car looks a very sorry sight. I measure the extent of the lean by checking with a clenched fist on either side. On the left I cannot get a clenched fist between tyre and wheel arch; on the right I can get a fist and a half.
It has been to the dealer with this issue and they assured me it was all down to the wrong software loaded onto the central controller. Apparently I had RR Vogue software loaded and they explained it that my car was trying to do things it wasn't built to do. This did seem to cure it for 3 weeks but now my lean is back. Obviously a trip to the dealers seems to be on the cards again but was wondering if there are any explanations for this? All seems OK when the car is driven.
Also, my two keys regularly lose their settings and seem to reset themselves to factory settings; ie, I lose all lazy entry settings, the landrover button returns to switch headlights on not open tailgate as programmed. This is now getting frustrating can anybody explain why or is it something I'm doing wrong? I do not disconnect the battery at all.
Thanks all. RRS TDV8 Java/Ebony, Privacy
New Model 07 Mini Cooper S Blue with white stripes
Debating RRS TDV8 in Stornaway or Jag XF SV8?
Post #150527 Fri Jan 04 2008 8:46pm
Hi
I believe this is just a sensor problem - it has been discussed before a few times - in fact, I think JayMan may have had this problem in the past and it was resolved by replacing a suspension sensor - I'm sure someone will confirm if this is correct shortly
Post #150528 Fri Jan 04 2008 8:56pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Definately sounds like a faulty ride hight sensor to me.
As for the wrong software Confused Sounds like your dealer doesn't have a clue what he is talking about. RR Vogue and the RRS are built in two completely different buildings, using two completely different on board diagnostic systems. How on earth could the wrong software be loaded? Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #150531 Fri Jan 04 2008 9:05pm
PLidds
TB - Thanks for this; my local dealer is German and they probably don't get the throughput of issues to buid-up a good knowledge base so I'm just trying to get some responses to be able to point them in the right direction on my second visit. RRS TDV8 Java/Ebony, Privacy
Post #150535 Fri Jan 04 2008 9:17pm
TB
Good luck in resolving the fault with your moter.
Let us all know how you get on with your dealer. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #150536 Fri Jan 04 2008 9:20pm
Bobby
PLidds, there was a bulletin on this early this year...
http://www.rrsport.co.uk/gallery/albums/us...arked1.pdf
hopefully this will help.
Cheers. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #150550 Fri Jan 04 2008 10:48pm
PLidds
Cheers.
Bobby - thanks for this; the attached bulletin seems to cover the exact problem. Will print-out and take to dealer om Monday.
Anybody got any info on the key issue?
Thanks,
PL RRS TDV8 Java/Ebony, Privacy
Post #150576 Sat Jan 05 2008 7:33pm
As Kaine said just a sensor problem
and this at just a week old Big Cry Big Cry
 RRS TDV6 Gone but still around
Post #150583 Sat Jan 05 2008 9:34pm
As for you key settings check that your car battery is OK if not that get them to check your ECU. 2005 Zambezi TDV6 - Gone but not forgotten
Post #150588 Sat Jan 05 2008 10:30pm
Bobby
PLidds, any luck with the 'Lop-Sided' issue? Malaysia Boleh!
Post #151805 Tue Jan 15 2008 10:54pm
Must be fixed and now he can't pull himself away from the car to come back and tell us! Laughing
Post #151812 Wed Jan 16 2008 8:20am
Bobby
For his sake, I hope so. Smile Malaysia Boleh!
Post #151819 Wed Jan 16 2008 8:34am
PLidds
Sorry all; been away working for the week for a change. Not had time to check-in. Picked the car up this morning from the local stealer and as predicted by you clever folk it was a sensor issue this time. Wonder how long this will last until it starts to list again. Is this generally a recuring problem?
Can't wait to take her down the autobahn tomorrow - been in a Saab 9-5 all week. What a bore!! RRS TDV8 Java/Ebony, Privacy
Post #152158 Sat Jan 19 2008 5:14pm
Thumbs Up RRS TDV6 Gone but still around
Post #152171 Sat Jan 19 2008 10:48pm
PLidds
Been down the autobahn and now the rear left brakes are sticking. Stank and was extremely hot when I got back and the excess brake dust also gave things away. Tried applying and releasing handbrake a number of times but still seems to drag significantly. Another trip back to the dealer needed. Also Sat Nav brigthness is always dull now even with lights off and limbar control has fell off seat. I'm sure all will be sorted one day. RRS TDV8 Java/Ebony, Privacy
Post #152193 Sun Jan 20 2008 1:43pm
