![]() | Home > General > Roof Rails |
d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
Having just fitted them, yes the dealer is correct as once fitted they cannot be removed as it would leave holes in the plastic trim on the roof.
AC Member Since: 01 Nov 2005 Location: Chicago, Il Posts: 12 ![]() ![]() ![]() |
Matt,
That is true - each rail is held down by three screws. If removed, you could block the three large 19mm holes in the trim with rubber grommets (electrical grommets are 20mm I think), so that water doesn't get trapped under the trim. Matt
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Roof rails that can't be removed? Who designed those? Mickey Mouse? L319 D4 HSE
The rails can be removed. It is just the side tracks that are fixed. Matt
I know, but still, not great design is it? L319 D4 HSE
The Sport should come with fixed side rails like estate cars and many other 4x4s do. Matt
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 ![]() ![]() ![]() |
Maybe someone will design a roof rail aka X5/XC90. With the right design could look good. Rob *Gone - HSE TDV8 Rimini Red + Tasmod sill plates |
vip-culture.com Member Since: 12 Feb 2006 Location: The OC Posts: 86 ![]() ![]() ![]() |
Matt,
No. The fire extinguisher came with a wire bracket - as they all do. I simply fixed this to the cross bar under the seat with two self tapping screws. Very simple. Matt
Full details on fire extinguisher mounting in this thread http://www.rrsport.co.uk/forum/viewtopic.php?t=1265 Matt
thanks matt, i just notice that post now www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
