Home > General > Roof Rails
AC
United States 2006 Range Rover Sport Supercharged Java Black
Roof Rails
I would like to get the roof rails for the 3 times I would need during the year. Since I like the way the car looks without it, I would like to have the ability to take them off when not in use. The service guy at the dealer said they would need to stay on once installed. Installation itself did not look easy so I guess I would get wacked to get it done.
Anyone have them put on and know if they can be taken off easily? Anyone know of other options?
Thanks in advance. AC
Post #4492 Tue Nov 01 2005 6:20pm
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Having just fitted them, yes the dealer is correct as once fitted they cannot be removed as it would leave holes in the plastic trim on the roof.
See my gallery for pics of the tracks. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #12966 Mon Feb 13 2006 10:03pm
AC
Matt,
That was very nice of you and your help is much appreciated. Since the rails are held down by screws, isn't all involved in removing them is to unscrew them? I understand that the holes in the trim piece will be permanant but they wouldn't be visible unless you're very tall.
Thanks again. AC
Post #13346 Thu Feb 16 2006 3:52pm
d3matt
That is true - each rail is held down by three screws. If removed, you could block the three large 19mm holes in the trim with rubber grommets (electrical grommets are 20mm I think), so that water doesn't get trapped under the trim. Matt
Post #13347 Thu Feb 16 2006 4:01pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Roof rails that can't be removed? Who designed those? Mickey Mouse? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #13393 Thu Feb 16 2006 5:21pm
d3matt
The rails can be removed. It is just the side tracks that are fixed. Matt
Post #13401 Thu Feb 16 2006 7:03pm
RRUK
I know, but still, not great design is it? L319 D4 HSE
1982 Series 3 SWB
Post #13454 Fri Feb 17 2006 12:02pm
d3matt
The Sport should come with fixed side rails like estate cars and many other 4x4s do. Matt
Post #13487 Fri Feb 17 2006 1:10pm
Robbi
Guernsey 2007 Range Rover Sport TDV8 HSE Rimini Red
Maybe someone will design a roof rail aka X5/XC90. With the right design could look good. Rob
*Gone - HSE TDV8 Rimini Red + Tasmod sill plates
Post #13626 Sat Feb 18 2006 9:39am
vip-culture.com
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
Matt,
Sorry for the thread jack. but i noticed the location of your extinguisher mounting location and that's a great place!
did you have to buy special mounts to do this? www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Post #15046 Wed Mar 01 2006 7:22am
d3matt
No. The fire extinguisher came with a wire bracket - as they all do. I simply fixed this to the cross bar under the seat with two self tapping screws. Very simple. Matt
Post #15069 Wed Mar 01 2006 10:05am
d3matt
Full details on fire extinguisher mounting in this thread http://www.rrsport.co.uk/forum/viewtopic.php?t=1265 Matt
Post #15074 Wed Mar 01 2006 10:11am
vip-culture.com
thanks matt, i just notice that post now www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Post #15178 Wed Mar 01 2006 7:41pm
