Home > General > Noticed something odd tonight w/ the transmission |
vip-culture.com Member Since: 12 Feb 2006 Location: The OC Posts: 86 |
I was heading home tonight from work and noticed my tranny doing something very odd that it normally doesnt do on the same road.
Tue Feb 28 2006 4:51am |
I've noticed this behaviour too. I live down in the bottom of a valley and have an uphill journey out in the morning. Seems to happen there too, but as the engine/gbox are always cold at that point I'd put it down to that... I guess that's not the case for you, VIP?
Tue Feb 28 2006 9:32am |
no definitely not...by the time i get to that portion of the road ive been driving for a good 15 mins already. I didnt notice it as much today as the roads were dry...it only happened once on the downhill run. www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Wed Mar 01 2006 3:21am |
Odd behaviour then... for what it's worth, have you run it past your service dept?
Wed Mar 01 2006 10:12am |
not yet, i'll keep an eye on it and see if it acts up some more www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Wed Mar 01 2006 7:40pm |
ok here's my theory.
Fri Mar 03 2006 3:41am |
well you could still be right... www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Fri Mar 03 2006 4:23am |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
It's probably normal in my opinion... and if it really bugs you, use manual shift mode... or waste more fuel and see how Sport mode impacts your scenario. I've never had an automatic transmission act exactly like how I'd shift using a manual. Remember, the RRS is the heaviest vehicles in it's class. Pity the engine & transmission that has to deal with this mass. As you get more time with your vehicle, you'll start getting a better feel for it's behavior. It trains you. (And you train it.) The transmission is adaptive, so behavior can change as time goes on. |
Fri Mar 03 2006 4:43am |
i do forget that i'm driving a huge tank www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Fri Mar 03 2006 4:47am |
I'm not sure if the LR gearboxes have the same function but BMW auto gearboxes have a set of tilt switches in them that shows the gearbox you're on a downward slope and should therefore change down to provide some amount of engine braking.... this is speed-sensitive obviously and is normally only something you'd do at lower speeds and greater inclines, not at 80mph on a motorway..... just a thought though.
Fri Mar 03 2006 9:16am |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
If BMW have it, then it is odds on that LR have it. Seeing as the sneeky Germans nicked our technology. |
Fri Mar 03 2006 9:45pm |
