![]() | Home > General > Noticed something odd tonight w/ the transmission |
vip-culture.com Member Since: 12 Feb 2006 Location: The OC Posts: 86 ![]() ![]() ![]() |
I was heading home tonight from work and noticed my tranny doing something very odd that it normally doesnt do on the same road.
I've noticed this behaviour too. I live down in the bottom of a valley and have an uphill journey out in the morning. Seems to happen there too, but as the engine/gbox are always cold at that point I'd put it down to that... I guess that's not the case for you, VIP? |
no definitely not...by the time i get to that portion of the road ive been driving for a good 15 mins already. I didnt notice it as much today as the roads were dry...it only happened once on the downhill run. www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Odd behaviour then... for what it's worth, have you run it past your service dept? |
not yet, i'll keep an eye on it and see if it acts up some more www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
ok here's my theory.
well you could still be right... www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
It's probably normal in my opinion... and if it really bugs you, use manual shift mode... or waste more fuel and see how Sport mode impacts your scenario. |
i do forget that i'm driving a huge tank www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
I'm not sure if the LR gearboxes have the same function but BMW auto gearboxes have a set of tilt switches in them that shows the gearbox you're on a downward slope and should therefore change down to provide some amount of engine braking.... this is speed-sensitive obviously and is normally only something you'd do at lower speeds and greater inclines, not at 80mph on a motorway..... just a thought though. |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
If BMW have it, then it is odds on that LR have it. Seeing as the sneeky Germans nicked our technology. |
