Home > General > Decisions on New tyres
BoatMad
Ireland 2007 Range Rover Sport TDV8 HSE Java Black
Time to replace 4 conti,
reading through the various posts I'm still a little confused
Questions
(a) I have a HSE TDV8 with factory 20" stormers, can I fit 295 40 instead of 275 40
(b) Whats the views on alternatives to the Conti's ( I dont need M+S), there seems to be a consus on Pirelli scorpions or what about the Hankook RH06 ( would you be worried it only comes in W varient)
Thanks listess RRS HSE TDV8 Java black/Ebony interior, mud flaps,20" stormers, towing, roofrack,sunroof,cooler V8 Tasmods Sills,black badges, carstyling java black vents
Previously FFRR TD6 Metallic Grey
Post #151534 Mon Jan 14 2008 12:38am
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
How many milage you did on the continantal tires?
I really con't find better that Continantal for the RRS supercharged there are soft and quit 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #151536 Mon Jan 14 2008 3:33am
Bobby
I changed to PIRELLI PZERO and feel they are better. Thumbs Up Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #151537 Mon Jan 14 2008 6:17am
exalld
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Pirelli road noise is better (especially on motorways) than Conti. 2007 Range Rover Sport TDV8, Stornoway Grey
Post #151629 Mon Jan 14 2008 2:28pm
BoatMad
I got about 30K miles on them RRS HSE TDV8 Java black/Ebony interior, mud flaps,20" stormers, towing, roofrack,sunroof,cooler V8 Tasmods Sills,black badges, carstyling java black vents
Post #151631 Mon Jan 14 2008 2:55pm
Rupert
Ireland
Not sure how the 295 / 40’s will work, but all I can say, besed on personal experience, is that 295/45 Pirelli’s do not work with OEM LR Stormers !!!
As I found out, they give no clearance at all.........
I tried them for a day, but then took them off & found evidence of rubbing on the tyres Shocked
It seems that there is no problems with 295/40’s on copy Stormers as the offset is greater than then OEM rims. So my advice is to be careful & choose wisely
Post #151760 Tue Jan 15 2008 1:23pm
BIRDY
My car pulled to the left from new fitted 4 Michelins cured Laughing Blick with blick windows, big wheels, tow bar for nickin, side steps for the tart, DVD screens for on the go porn, 22" Stormers black and polished... as a matter of fact just about every box ticked.....if I`m going down I`m going down BIG time. Wink))
Ducati 1098S for the road and track and KTM 250EXC smoker for the mud.
Post #151775 Tue Jan 15 2008 2:53pm
BoatMad
rupert , I read your trials and tribulations re extra width. There does seem to be some issue that the 20" stormers with teh brembo brakes have extra width , any comments RRS HSE TDV8 Java black/Ebony interior, mud flaps,20" stormers, towing, roofrack,sunroof,cooler V8 Tasmods Sills,black badges, carstyling java black vents
Post #151877 Wed Jan 16 2008 12:25pm
JJF701
Do you find that with the 20 inch stormers, the speedo is inacurate? It reads different to my road angel speed display which is supposed to be correct. I assume this is something to do with the fact that the V6 diesel was not designed to have the 20 inch wheels as standard???
Post #151879 Wed Jan 16 2008 12:32pm
Rupert
Ireland
BoatMad
Not sure about the Brembo equipped RRS’s have a great offset, but it is something that could be possible.
I do recall though when I was having my issues, the service manager at the dealer checked to see if the TDV8 had any different suspension set ups to the TDV6 & he could find no differences at all. But that’s not to say that the Brembo calliper / hub set up doesn’t have a greater offset. As it was suspension geometry we were looking at.
Good Point though Thumbs Up
JJF701
Can’t say I found any difference in the speedo readings, when I was running the Stormers. But I didn’t have anything to check it against such as a Road Angel or the like.
When I use an online tyre size calculator, to compare the stock 18” to the 20” Stormer set up, it tells me that the speedo will read 1.3% too fast, translating to an indicated speed of 60MPh being an actual speed of 59.2 MPh
A difference I can certainly live with, particularly when it’s erring on the too fast side.
Post #151886 Wed Jan 16 2008 1:00pm
The rolling radius of the wheel/tyre remains fairly constant between all the wheel options available from LR so this isn't much of an issue. The speedo will never be as accurate as your GPS anyway Very Happy
Post #151887 Wed Jan 16 2008 1:02pm
There shouldn't be an real difference as the diameter of the wheel with tyres on is virtually the same. This Road Angel difference has been noted before. 2005 Zambezi TDV6 - Gone but not forgotten
Post #151888 Wed Jan 16 2008 1:02pm
Stop copying what I say!!! Shocked
Post #151889 Wed Jan 16 2008 1:03pm
Censored Censored Censored Censored 2005 Zambezi TDV6 - Gone but not forgotten
Post #151890 Wed Jan 16 2008 1:03pm
Rolling Eyes
Post #151891 Wed Jan 16 2008 1:07pm
