![]() | Home > Technical > Windscreen washers |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Anyone had a problem before with front and rear wash jets not working? Headlight jets work but front and rear screen jets dead. |
cowey101 Member Since: 17 Jul 2007 Location: Gods country! Posts: 403 ![]() ![]() ![]() |
Are they not just frozen? |
Phantom Member Since: 20 Oct 2007 Location: Belgium - Ohain Posts: 102 ![]() ![]() ![]() |
They are supposed to be heated, I'll test mine tommorow morning, it's freezing nicely over here |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
how do you get the rear washer working?! |
I think you pull the stalk don't you - i do it without thinking - if no one else chirps in i'll go out and check. ![]() |
Cheers ![]() |
Cheers Tim ! |
db Member Since: 28 May 2007 Location: London Posts: 19 ![]() ![]() |
yep mine have failed also...the windscreen washers I mean |
http://www.rrsport.co.uk/forum/topic1057.h...en+washers
Nice one db - this had crossed my mind i just hadn't got around to opening the manual to find out where they were etc |
Forgot to report back, mine were working with -6°C outside, so they are heated but you do need to wait 1min before they will work. 08.5 RRS TDV6 HSE Java Black/Alpaga - Cold Climate Pack - Privacy Glass - Bluetooth - Sunroof - 20" wheels - Rubber Floor mats.
Its the fuse alright....
Done! - what designer placed the spare fuses there |
