Home > Technical > Windscreen washers |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Anyone had a problem before with front and rear wash jets not working? Headlight jets work but front and rear screen jets dead. |
Tue Dec 18 2007 5:37pm |
cowey101 Member Since: 17 Jul 2007 Location: Gods country! Posts: 403 |
Are they not just frozen? Java Black TDV6 HSE - Java Grandes Marques 1/18 - Ducati 749s |
Tue Dec 18 2007 5:40pm |
well - thought that but temp has been up to 5 deg and still inop - would the headlamp jets not also be frozen if that the case ?
Tue Dec 18 2007 5:43pm |
Phantom Member Since: 20 Oct 2007 Location: Belgium - Ohain Posts: 102 |
They are supposed to be heated, I'll test mine tommorow morning, it's freezing nicely over here 08.5 RRS TDV6 HSE Java Black/Alpaga - Cold Climate Pack - Privacy Glass - Bluetooth - Sunroof - 20" wheels - Rubber Floor mats.
Tue Dec 18 2007 5:56pm |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 |
how do you get the rear washer working?! |
Tue Dec 18 2007 6:17pm |
I think you pull the stalk don't you - i do it without thinking - if no one else chirps in i'll go out and check. |
Tue Dec 18 2007 6:20pm |
Cheers |
Tue Dec 18 2007 6:21pm |
Cheers Tim ! |
Tue Dec 18 2007 7:01pm |
db Member Since: 28 May 2007 Location: London Posts: 19 |
yep mine have failed also...the windscreen washers I mean
Fri Dec 21 2007 12:24am |
http://www.rrsport.co.uk/forum/topic1057.h...en+washers
Fri Dec 21 2007 12:32am |
Nice one db - this had crossed my mind i just hadn't got around to opening the manual to find out where they were etc lazy will look at today... Good find, nice work, Merry Christmas all ! |
Fri Dec 21 2007 6:59am |
Forgot to report back, mine were working with -6°C outside, so they are heated but you do need to wait 1min before they will work. 08.5 RRS TDV6 HSE Java Black/Alpaga - Cold Climate Pack - Privacy Glass - Bluetooth - Sunroof - 20" wheels - Rubber Floor mats.
Fri Dec 21 2007 8:58am |
Its the fuse alright....
Fri Dec 21 2007 7:13pm |
Done! - what designer placed the spare fuses there spare fuse flipped out and ended up down the back of the trim ?!?!?! had to take trim out to get to it ............................ |
Sat Dec 22 2007 2:55pm |
