Home > Technical > help petrol stations |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
In the settings menu select display POI's and make sure Fuel Stations are one of your required POI's. From memory you may need to have it zoomed in 2 miles as a minimum (just in case you have zoomed out at any point).
Wed Dec 12 2007 9:21pm |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 |
Thank you Charles Hurst Park Royal I will try that later tonight What I can't understand is why aren't you at work I am |
Wed Dec 12 2007 9:25pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Told you! RRS TDV6 Gone but still around
Wed Dec 12 2007 9:40pm |
cherrybay Member Since: 04 Nov 2005 Location: Belgium /Greece Posts: 53 |
mine is going crazy aswell , today i got in my car and the satnav was in english (normally Dutch) and when i stopped the car an hour later and started again it was back on Dutch ??? also my "home" was moved a kilometer or so ??
Wed Dec 12 2007 10:17pm |
Ok smarty pants. Up late weren't you on a school night, so was i |
Thu Dec 13 2007 8:45am |
Yeah, the icons only appear when zoomed into 2 miles or below as James says. Things used to disappear from mine sporadically too and I'd have to re-add them. Is it all sorted now Si?
Thu Dec 13 2007 8:50am |
C RRS TDV6 Gone but still around
Thu Dec 13 2007 8:51am |
I'm always zoomed in less than 2 miles, am going out this morning so will check and let you know but thanks again for the help. |
Thu Dec 13 2007 8:55am |
