![]() | Home > Technical > help petrol stations |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
In the settings menu select display POI's and make sure Fuel Stations are one of your required POI's. From memory you may need to have it zoomed in 2 miles as a minimum (just in case you have zoomed out at any point).
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
Thank you Charles Hurst Park Royal I will try that later tonight |
Told you! RRS TDV6 Gone but still around
cherrybay Member Since: 04 Nov 2005 Location: Belgium /Greece Posts: 53 ![]() ![]() ![]() |
mine is going crazy aswell , today i got in my car and the satnav was in english (normally Dutch) and when i stopped the car an hour later and started again it was back on Dutch ??? also my "home" was moved a kilometer or so ??
Ok smarty pants. Up late weren't you on a school night, so was i ![]() ![]() ![]() |
Yeah, the icons only appear when zoomed into 2 miles or below as James says. Things used to disappear from mine sporadically too and I'd have to re-add them. Is it all sorted now Si? |
C |
