![]() | Home > Technical > Lazy Entry |
Simon Member Since: 13 Jun 2005 Posts: 44 ![]() ![]() |
If you know where it is in the infp screen I think that's it, just turn it on for your key and do the same thing with the other key for your wife. Then all you have to remember is to use the right key |
Sorry, just realised should have said partner ![]() |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
She would be glad if it was, |
Spent the night playing with various bits,
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
While sitting parked with the key in the ignition and not started, set the position on your seat and mirrors to your liking... then press MEM on the seat followed by 1 (or 2, or 3). This will bind your preference to the key in the ignition. Now, when opening the door with the key fob... the seat & mirrors should adjust to the key setting if you have "Lazy Entry" enabled. |
Thanks Grommet,
Biggles,
Biggles,
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
What a shame though they didn't tie in the steering column into the memory electrics, that was just a silly marketing ploy, used to try and show there is a difference between the Range Rover and the Sport....when I am paying nearly £60 grand for a car I expect it to have these features, plus a TV tuner too! |
How lazy am I,
