![]() | Home > Technical > LPG Injection - TDV6 |
stephenw Member Since: 12 Nov 2006 Location: Canberra ACT Posts: 91 ![]() ![]() ![]() |
I just had a very interesting discussion with (what I think as) a very good non-LR LR service guy in Canberra. He is now putting LPG injection kits into Disco3s and RRSs and has had some very good results.
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
Can diesel been converted to LPG answer:
So now we know |
Same here did know it could be done
Been hunting around and found this...
Cool i guess it can be done then but the last time i looked in to the was about 7/8 years ago things do move on a bit |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Sorry rrsjo, I have been busy. You can fit it to Diesel but you are mixing the 2 fuels together to get better combustion quality, You normally get between 75-87% efficiency from any diesel but if you also inject LPG you get nearly 96-98% efficiency. Normally the fuel saving is only about 20-35% so you need to weigh up is it worth it. You can get more torque and fuel economy than standard from an up-grade so I would not bother. Just re-map. If you talk to the USA or Australians that are using it they will go into a great detail about fuel saving by turning off the injectors when you are slowing down on the overun, this has been the case on all petrol cars for 25 years and all Diesels in Europe and UK for about 11 years. If you inject fuel on the overun you get a very slight surge on the car when slowing down. Go down a street tonight in your RRS where you have enclosed sides-high buildings holding in the noise- or a bridge. Open the drivers and passenger window, When you let go of the throttle listen to the engine note as the RPM clock comes back down past 1500-1200rpm, you will hear the Diesel knock come back on as the fuel starts going back through the injectors into the engine. So there is no fuel saving there. Personally I would not bother the saving is not enough. When you are filling up a FFRR 4.4 with £30 of LPG instead of £90 of petrol it is worth it. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
There is a D1 that races and is an LPG diesel for the extra power. As I understood it, it is rather technical and what a D3/RRS would make of it I don't know. Have a go and let us know! |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Not financially worth doing to a diesel. |
Its not the economy you do it for, its the power |
happydays Guest ![]() |
Done a teeny weeny bit of digging. Apparently if you 'detune' you cars engine management by having a 'remap' to reduce the power and then add LPG it will give you back the power you have lost plus an increase in economy of 20%.....sounds the way to go but not sure LR would agree |
To be honest the power and torque increase is the design as pelyma pointed out, but the fuel saving is not that good.
