Home > General > Diesel Additive
Cliff H
Can't get either around here Banging Head Laughing
Post #139435 Tue Sep 25 2007 7:23pm
Lateral5
Australia
Josh wrote:
May I suggest spending a few more pennies (sore subject I know Exclamation Rolling with laughter ) at the pump by filling up with BP Ultimate diesel or the Shell version if you can find it. They've got the additives built into the fuel......so clean injectors. Can't breach the warranty by using good fuel. Wink
I generally use BP or Shell.....but I am not sure if they are anything more than bog standard diesel in Australia. The pump just says.....Diesel, no premium, no ultimate. They only recently went to less than 50ppm Sulphur in this country.
Do they market better grade diesel grades in UK/Europe ? Can you notice the difference? As I understand it, the only difference is a higher Cetane rating, which ironically you can get through an additive.
I must say the additive I have been using has reduced the smoke quite significantly under hard throttle. RRS TDV6 Bluetooth, VR, Roof
Post #139485 Wed Sep 26 2007 12:29pm
BigMart
"Hard Throttle"
That's the spirit!
Mart Thumbs Up Thumbs Up Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #139568 Wed Sep 26 2007 6:29pm
