Home > General > Diesel Additive |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 |
Can't get either around here |
Tue Sep 25 2007 7:23pm |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
I generally use BP or Shell.....but I am not sure if they are anything more than bog standard diesel in Australia. The pump just says.....Diesel, no premium, no ultimate. They only recently went to less than 50ppm Sulphur in this country. Do they market better grade diesel grades in UK/Europe ? Can you notice the difference? As I understand it, the only difference is a higher Cetane rating, which ironically you can get through an additive. I must say the additive I have been using has reduced the smoke quite significantly under hard throttle. RRS TDV6 Bluetooth, VR, Roof |
Wed Sep 26 2007 12:29pm |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 |
"Hard Throttle"
Wed Sep 26 2007 6:29pm |
