Home > Technical > KNOCKING NOISE COMING FROM FRONT END
Page 6 of 8 <12345678>
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
I hear exactly where you are coming from The Biggy, mine is still knocking and with no resolve either, and like you there is not another vehicle out there at the moment that i would prefer to be in as my every day car, but trust me Landrover if you are reading this, i am sure that if there were a suitable replacement for the RRS then many of us would of jumped ship Evil or Very Mad some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #132569 Mon Aug 13 2007 4:03pm
thebiggy
Sad Sad
Has anyone out there actually been offered anything by Land Rover for all of the hassle we have had I.E. replacement car, moneyback, compensation etc?
Post #132578 Mon Aug 13 2007 4:24pm
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
thebiggy wrote:
Sad Sad
Well biggy I tried the rejection process only a few weeks ago because the knocking was not the only issue. The supplying dealer had a LR steering expert out, from the factory, to look at the car and he broke the fuse box which is part of the wiring loom whilst removing the DR fuse. They offered to try and fix it by making another way of holding the lid on because it was such a big job to rectify but I refused. I lifted up the harness and pulled it out and found where the TW##T had thrown the plastic bit and plastic welded it back on. There were also marks all over the leather and they have since replaced the back seat and cubby box lid. When I tackled LR I was under the impression that I was getting a new replacement vehicle with a charge for the miles you have got on the clock. Which I would have accepted. By the time I reached the supplying dealer they had discussed it with LR and I had to speak to the new sales manager because he had taken the telephone call from LR. I was told that because all the other issues could be rectified the only one that was impossible to cure was the DR knock and because of this being a characteristic of this vehicle - a rejection was not possible.
It has been back again twice since, it now has 3 marks on the exterior that was not there when I left it, and is going into another dealer agaiin today. It is the most expensive car i have ever bought and the worst. Half the things I ask the dealers to do they can't so I have to do it myself at home. When I worked in the Rover dealers ia the late 70's and they were LR and Rover combined we dreaded the RR coming through the door because we called them the devil - Poorly built with inferior parts - but unfortunately nothing has changed as far as I can see. I feel like setting fire to it. I hope you get some where with yours. Thumbs Up You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #132637 Tue Aug 14 2007 7:49am
frizz
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Well I test drove my car this morning with the mechanic. Still getting a knocking sensation through the steering wheel, and fortunately the mechanic felt it too. He concluded that it was more pronounced under heavy braking and accelerating. So hence the car is staying at the dealers.
The only thing I have been given by LR apart from an ulcer is a set of side steps f.o.c 'cos I asked for them.
I often wonder, how long is an unreasonable amount of time with faulty car ( three months so far) before I can get a refund.
Post #132687 Tue Aug 14 2007 11:05am
Nutty Nige
To be fair frizz the staff have been really good as have LR customer services but the actual hands on is so bad the incompetance is a joke. I told LR that my trips to the dealers have now cost time off work, and 500 miles on the clock, 70 quid in Diesel, and they said ask the supplying dealer to give you compensation in the way of a gift like yours so I asked for privacy glass and got told no. I would prefer a full refund like you just said. You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #132695 Tue Aug 14 2007 11:33am
rrsjo
Just a thought Idea
Has anyone else noticed that almost without exception the 'accurate' reports of this ARC noise come from owners of right hand drive vehicles. For example, the SC is fitted with this ARC valve and I cannot recall US owners reporting this problem and rejecting vehicles.
Any difference between LH and RH drive vehicles and hence a clue to the problem?
Post #132698 Tue Aug 14 2007 11:40am
frizz
You may have a point rrsjo.
Some-thing I've been thinking about for a few weeks.
In the owners handbook the recommended fluid for the DRS is texaco cold climate PAS. Maybe the fluid used in the export models is of a higher viscosity to tolerate the higher ambient temps of hotter climes, hence dampening the movement of the valve in the pump housing. I wouldn't have thought that the operating system is any different to UK spec vehicles, that is of course, if it is fitted in the first place.
I must admit that on a cool morning my arc pump makes no noise until about a mile or two up the road when the oil in the system has warmed up.
The fact that the pump is mounted directly to the engine cannot help as the engine itself would amplify the noise to some degree.
Post #132746 Tue Aug 14 2007 4:10pm
thebiggy
Smile Just to let you know that I emailed our local TV station about the problems we are having with our Sport and said to them that its a much wider issue than just our car. Its every HSE that has the arc noise. plus our other knocking noise. They are interested in our story and may possibly come and film us and the car. I hope they do as it will highlight their lack of customer care and their avoidance of the issues. We live in Solihull where the vehicles are made and I'm sure they won't want the publicity this is bound to bring. Will let you know if they come to film us. Smile Wink
Post #132747 Tue Aug 14 2007 4:20pm
frizz
That's excellent the biggy.
Incidently, My local oil specialist tells me I am not the first owner of a RRS to inquire about different oils that can possibly be used in place of the recommended texaco cold climate PAS. But he advised me to stick with it for the time being. The reason...... LR could invalidate the warranty on my vehicle, and they probably would!
Post #132751 Tue Aug 14 2007 4:52pm
rrsjo
rrsjo wrote:
Just a thought Idea
So how many of you LH drive owners have Dynamic Response fitted and have this knocking coming from the ARC valve - or is yours OK?
Post #132753 Tue Aug 14 2007 5:13pm
Nutty Nige
I have mentioned this before frizz. I tested the oil in our quality section at work and the so called Texaco cold climate stuff is actually Texaco Dexron 3 Auto transmission fluid. I have been working on it with some people from USA and also some Swiss people who used to employ Dr Landis the man who invented Mobil 1. I am going to drain some of the fluid off when I get the car back from the dealers and add a supplement to it. The next step if that does not work is replace the Dexron 3 with Dexron 5. As soon as I have an answer I will let you know. LR use the same oil in the climates that you mention but you are right about the viscosity because I noticed that the more I drive and the hotter it gets the worse the ARC noise is, obviously as the oil gets thinner with the heat. The supplement I am going to add gives it the negative molecules to stop it breaking down and make it more efficient and more heat resistant. I am keeping my fingers crossed. Sad You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #132779 Tue Aug 14 2007 7:40pm
Bobby
What an excellent thread!
Keep it up guys!! Thumbs Up Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #132858 Tue Aug 14 2007 10:55pm
frizz
Here we go again!
Called the dealer to see if the have made any progress on my car regarding the clonking sensation through the steering wheel when braking and accelerating from standstill.
The reply was........."Oh, we've got a couple here that do the same, so it's a characteristic of the car".
What a load of crap! Didn't do it when I bought the car , does it now, so some-thing is faulty, surely?
Has or does anyone experienced the same. If so, was it fixed?
frizz.
Post #133010 Wed Aug 15 2007 4:14pm
Nutty Nige
The only characteristic of the car you should have is the clonk when you snatch the steering wheel at 20mph from the arc valve in the DR system. Any other problem is NOT a characteristic Evil or Very Mad
Make them put it right. You don't stop playing because you get old, You get old because you stop playing.
Audi TT
Post #133111 Thu Aug 16 2007 8:26am
When I bought my RRS the sales broucher told me about the wonderful driving position, the good looks, the 4x4 capabilities - I don't remember ever seeing anything about an annoying clonk - if it's a characteristic of the car they should advertise it! 2005 Zambezi TDV6 - Gone but not forgotten
Post #133167 Thu Aug 16 2007 5:54pm
