![]() | Home > Technical > KNOCKING NOISE COMING FROM FRONT END |
thebiggy Member Since: 26 May 2007 Location: solihull Posts: 34 ![]() ![]() ![]() |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Well biggy I tried the rejection process only a few weeks ago because the knocking was not the only issue. The supplying dealer had a LR steering expert out, from the factory, to look at the car and he broke the fuse box which is part of the wiring loom whilst removing the DR fuse. They offered to try and fix it by making another way of holding the lid on because it was such a big job to rectify but I refused. I lifted up the harness and pulled it out and found where the TW##T had thrown the plastic bit and plastic welded it back on. There were also marks all over the leather and they have since replaced the back seat and cubby box lid. When I tackled LR I was under the impression that I was getting a new replacement vehicle with a charge for the miles you have got on the clock. Which I would have accepted. By the time I reached the supplying dealer they had discussed it with LR and I had to speak to the new sales manager because he had taken the telephone call from LR. I was told that because all the other issues could be rectified the only one that was impossible to cure was the DR knock and because of this being a characteristic of this vehicle - a rejection was not possible. It has been back again twice since, it now has 3 marks on the exterior that was not there when I left it, and is going into another dealer agaiin today. It is the most expensive car i have ever bought and the worst. Half the things I ask the dealers to do they can't so I have to do it myself at home. When I worked in the Rover dealers ia the late 70's and they were LR and Rover combined we dreaded the RR coming through the door because we called them the devil - Poorly built with inferior parts - but unfortunately nothing has changed as far as I can see. I feel like setting fire to it. I hope you get some where with yours. ![]() 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
frizz Member Since: 07 Jun 2007 Location: ashford kent Posts: 28 ![]() ![]() ![]() |
Well I test drove my car this morning with the mechanic. Still getting a knocking sensation through the steering wheel, and fortunately the mechanic felt it too. He concluded that it was more pronounced under heavy braking and accelerating. So hence the car is staying at the dealers.
To be fair frizz the staff have been really good as have LR customer services but the actual hands on is so bad the incompetance is a joke. I told LR that my trips to the dealers have now cost time off work, and 500 miles on the clock, 70 quid in Diesel, and they said ask the supplying dealer to give you compensation in the way of a gift like yours so I asked for privacy glass and got told no. I would prefer a full refund like you just said. You don't stop playing because you get old, You get old because you stop playing.
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
Just a thought |
You may have a point rrsjo.
That's excellent the biggy.
So how many of you LH drive owners have Dynamic Response fitted and have this knocking coming from the ARC valve - or is yours OK? |
I have mentioned this before frizz. I tested the oil in our quality section at work and the so called Texaco cold climate stuff is actually Texaco Dexron 3 Auto transmission fluid. I have been working on it with some people from USA and also some Swiss people who used to employ Dr Landis the man who invented Mobil 1. I am going to drain some of the fluid off when I get the car back from the dealers and add a supplement to it. The next step if that does not work is replace the Dexron 3 with Dexron 5. As soon as I have an answer I will let you know. LR use the same oil in the climates that you mention but you are right about the viscosity because I noticed that the more I drive and the hotter it gets the worse the ARC noise is, obviously as the oil gets thinner with the heat. The supplement I am going to add gives it the negative molecules to stop it breaking down and make it more efficient and more heat resistant. I am keeping my fingers crossed. ![]() 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
What an excellent thread!
Here we go again!
The only characteristic of the car you should have is the clonk when you snatch the steering wheel at 20mph from the arc valve in the DR system. Any other problem is NOT a characteristic |
When I bought my RRS the sales broucher told me about the wonderful driving position, the good looks, the 4x4 capabilities - I don't remember ever seeing anything about an annoying clonk - if it's a characteristic of the car they should advertise it! 2005 Zambezi TDV6 - Gone but not forgotten
