Home > Maintenance & Modifications > What’s life like with a set of Stormers ?? |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 |
Stormers are off again
Wed Jul 25 2007 9:06pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
Rupert, if you use this http://www.miata.net/garage/tirecalc.html to work out the difference between the 295 X 45 tyres you had on and the 295 x 40 tyres Envoy has, there appears to only be an additional 7mm clearance on top of the 2 mm your photo shows. This is no where near the 25mm + clearance that Envoy reports having. This points to a difference in the off set between the two wheels! In theory the LR ones should be correct. However, the evidence points to the fact that they are not. Even with 275 x 40 tyres fitted you will only obtain 13 mm clearance - again no where near the clearance Envoy is reporting with the wider 295 x 40 tyres.
Wed Jul 25 2007 10:20pm |
Yes indeed it would be great if someone else who has fitted Stormers to their TDV6 could check the clearances.
Thu Jul 26 2007 7:59am |
I said almost 4 pages ago I didn't think it was right....
Thu Jul 26 2007 11:32am |
Update……The saga has ended
Wed Aug 08 2007 11:13am |
Still doesn't seem to be a huge amount of clearance, but never having looked I don't know if this is normal or not Glad you got to the end Rupert
Wed Aug 08 2007 11:27am |
Well you'd slip a finger in the clearance..............if you pardon the expression
Wed Aug 08 2007 12:43pm |
Last Update on the Stormer Saga.
Mon Aug 27 2007 11:53am |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
looking good rupert |
Mon Aug 27 2007 1:03pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
Stormers do look the Muts, glad to see that you have resolved the issue , i am still a little confused as my tyres are 295,s and have good clearance so if any one else has 295's as Rupert said CHECK THE CLEARANCE and let us know |
Tue Aug 28 2007 7:10am |
Looking good Rupert - glad you've got a happy ending. Like E says though - I'm a bit confused over why you have so little clearance with them, they are so commonly fitted I can't imagine it not being raised as an issue before now. Anyway, you're happy which is the main thing
Tue Aug 28 2007 7:50am |
Cheers for the compliments guys
Tue Aug 28 2007 9:47am |
I seem to remember that there is a problem with the D3 when fitted with the RRS 19 inch wheels with Goodyear MTR's fitted. From what I remember there are instances of rubbing with these but i doesn't happen with the RRS, because of that I would conclude the RRS has more clearance. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Aug 28 2007 9:51am |
V8ogue Member Since: 16 Jan 2009 Location: Adana Posts: 2 |
hi guys, I'm quite new in here, got 2003 Range Rover 4.4 V8 Vogue Black, just found a set of Overfinch 22" wheels on internet and gonna buy them but I will need tyres for them of course, so what's the right size? I think they re 22x9. Your ego is my Lego!!! |
Fri Jan 16 2009 11:50pm |
