Home > Technical > Voice Dialing
Tedf
Denmark 2007 Range Rover Sport TDV8 HSE Java Black
Voice Dialing
I have a Nokia 6230i in the cradle. It works perfectly to dial from the directory, yet if I try to dial with voice commands, it responds " No handset connected".
Does anyone have similar experience? and better yet, a solution.
Thanks,
Ted
Post #130427 Tue Aug 07 2007 1:02pm
Pelyma
You have stored the numbers in the car rather than the phone?
Post #130442 Tue Aug 07 2007 3:55pm
Tedf
oh yes, painfully I recorded the names and phone numbers. It has worked, but now, I get a written message
"phone attached" but when I give the voice command " phone, dial name" the verbal response is " no phone connected"..???????
Thanks, Ted
Post #130455 Tue Aug 07 2007 5:29pm
Has the phone got the correct software? 2005 Zambezi TDV6 - Gone but not forgotten
Post #130456 Tue Aug 07 2007 5:44pm
Tedf
oh??
Would you know what the "corrrect software" is? Would that be from a particular version number?
Thank you......
Ted
Post #130457 Tue Aug 07 2007 5:51pm
Look here.
http://www.landrover.co.uk/gb/en/Owners/Le...Owners.htm 2005 Zambezi TDV6 - Gone but not forgotten
Post #130458 Tue Aug 07 2007 6:02pm
Tedf
thank you very much...very informative.
My software version is newer than the tested....Can you imagine it is necessary to "downgrade"?
Ted
Post #130486 Tue Aug 07 2007 8:06pm
No downgrade should be needed. The problem with this phone sytem on the RRS is simple - it's crap and bits that should work don't. Your not the first to experience problems and you will not be the last. I had similar problems and sorted them out by trial and error and replacing the phone for the most basic phone for the cradle. I have a phone always in the cradle. 2005 Zambezi TDV6 - Gone but not forgotten
Post #130491 Tue Aug 07 2007 8:12pm
Tedf
I too have a 6230i always in the cradle.....sometimes it works, somtimes not...just haven't been able to figure out why.
I see that there is a new firmware 3.89 ...mine is 3.88, so perhaps I'll try that...very frustrating.
Thanks so much for the feedback...
ted
Post #130534 Tue Aug 07 2007 9:21pm
My 6230i worked faultlessly UNTIL I upgraded the firmware on the phone... I then found I couldn't downgrade it to go back to what I had before. VA is right - generally, the PTI is a bit rubbish, although the MY08 RRSs have a newer Bluetooth module which may make things a bit better.
Post #130662 Wed Aug 08 2007 12:14pm
Tedf
ugh...doesn't sound encouraging
The voice dialing worked perfectly today ...for about 4 hours. then for no apparent reason, and I haven't touched the phone...it now again answers " no handset connected."...
a real hair puller...
Ted
Post #130816 Wed Aug 08 2007 3:12pm
Might be worth asking your dealer if you can get the MY08 bluetooth module swapped into your car? Word has it, it works a lot more seamlessly than the one you currently have Very Happy
Post #131125 Thu Aug 09 2007 7:50am
