Home > Maintenance & Modifications > What’s life like with a set of Stormers ?? |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 |
Back again, with another question………..
Mon Jul 02 2007 11:17am |
I've got an idea the 295/45 profile is actually the standard alternative to the usual 275s... so, should be plenty of happy users out there.
Mon Jul 02 2007 11:20am |
Ah !
Mon Jul 02 2007 11:36am |
Just to re-visit this thread once more, as I’ll soon be shoeing “Rupert” with his new rims.
Mon Jul 23 2007 9:28pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Your speedo will be about 6.3% too slow compared to the stock 275/40/20s, your mpg average will suck - but only on paper - and your odometer will equally record about 6.3 miles less for each 100 you actually drive, not necessarily a bad thing when resale time comes around. (I am not that smart by the way, you can easily do your own comparisons using tyre calculators such as this one: http://www.miata.net/garage/tirecalc.html ) Other than that - and perhaps a tad less road feel and precise handling due to the taller sidewall - you shouldn't have any problems: You should be well within the overall dimensions where potential rubbing may occur in certain conditions. The satnav has its own speed sensors / dead reckoning technology and will adjust to the new donuts in no time. |
Tue Jul 24 2007 12:19am |
You have 295/40s, E? Not 45s?
Tue Jul 24 2007 8:17am |
I was hoping to get the 295 40’s like ENVOY but in the end the 45’s came in “way” cheaper, so that combined with seeing that many on here recommended the 45’s over the 40’s that’s what I went for.
Tue Jul 24 2007 8:43am |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
Have you not thought of having the speedo recalibrated. I know on Jaguars this is easily done at the dealers by just plugging in and specifing the tyre size - I would have thought the same would apply to the RRS. After all, the factory must do the same when the different wheel sizes are fitted when the vehicle is built. |
Tue Jul 24 2007 8:52am |
You know, I’ll look into that rrsjo
Tue Jul 24 2007 8:55am |
Had the Stormers fitted to “Rupert” tonight & they look amazing.
Tue Jul 24 2007 9:47pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
I have had no issues with rubbing of my 295's some of my Previous cars
Tue Jul 24 2007 10:03pm |
Any idea how close they are to any components of the front suspension up at the top ??
Tue Jul 24 2007 10:26pm |
drevs Member Since: 04 Sep 2006 Location: USA Posts: 43 |
OT, but related... I had a set of offorad tires fitted to my RRS and they were damn close to rubbing on the upper spindle, right at the knuckle. I decided to pass, since the clearance was SO close. If you guys have ok luck with an extremely tight tolerance there, I may have to reconsider. Keep us posted. |
Tue Jul 24 2007 11:01pm |
Rupert i will double check this morning on the tyre size and i will look again at the clearance some of my Previous cars
Wed Jul 25 2007 7:12am |
