Home > Maintenance & Modifications > xenon vs Philips Crystal Vision
redrover
Australia 2007 Range Rover Sport TDV6 HSE Java Black
Hi All,
I have been doing a lot of research on retrofitting xenon's to my RRS and have come up with the following
1. It is better to go with original bi-xenon if you can find/afford them
2. Aftermarket xenon kits may cause focus issues (not to mention warranty)
3. Xenon are much brighter with a sharper cut-off which some people claim gives poorer night vision as your iris closes down more compared to halogen
4. You can't flash a xenon light if you replace the high beams as well
I have read some good reports on the Philips Crystal Vision which claim to have a whiter light and substantially increased light output, however they are pretty expensive at roughly half the price of a cheap xenon HID kit.
I would be most interested in people experience of xenon's and whether they really are better than a high quality halogen.
cheers,
Anthony
Post #127245 Sun Jul 22 2007 1:01pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
Imho, xenon is much better than hologen... it's bright, the light is clear... everything is better! 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #127246 Sun Jul 22 2007 1:25pm
Is this an easy job? I thought xenons require much more power...... Confused Runner up - 2009 Best Avatar Award Sad
Post #127283 Sun Jul 22 2007 8:02pm
MikeP
I'm not sure if I can get a Xenon kit for my 5 series so I've just ordered a pair of Crystal Vision.
I'll take a picture to show you the difference if your interested - let me know
Mike Michael Potter
Rangey Lover/BMW Driver
Post #127304 Sun Jul 22 2007 10:00pm
redrover
Hi Mike,
I would be very interested in your observations of the crystal vision.
Supertrotter - fitting after market xenon kits is meant to be pretty straight forward as you are just replacing the bulb and finding a spot to mount the ballast. They actually use less power than stock (35w vs 55w).
Post #127321 Sun Jul 22 2007 11:12pm
MikeP
Hi Red,
Got the bulbs delivered tuesday morning. Fitted them yesterday. Will show some pics soon! Michael Potter
Post #128105 Thu Jul 26 2007 12:13pm
Don't they take a bigger gulp of electricity at startup? Seem to remember having this conversation before...
Post #128107 Thu Jul 26 2007 12:16pm
MikeP
I seem to think that they use less electricity once they're running but I do believe that S is correct in saying that they require more power on startup because its an actual gas unit per'se and it takes a while for it to heat up to optimum which is in the region of around 4-5 seconds I believe.
I might be wrong but somehow I remember that. Michael Potter
Post #128203 Thu Jul 26 2007 6:16pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
28,000 volts. Don't touch!
Post #128391 Fri Jul 27 2007 11:47am
MikeP
Hi guys,
Sorry finally got around to taking some photos.
In the pic below is the normal sidelight bulb and then the main headlight which is the Philips Crystal Vision.
You can clearly see the colouration difference.
At night they do make a difference and looking at them in person they seem a hell of a lot whiter and a lot cooler as well - they do stand out more compared to your regular halogen bulb which we previously had.
They dont compare to Xenon as predicted purely as one is a gas unit and one is a bulb fair and square but they do look good! Michael Potter
Post #130360 Mon Aug 06 2007 10:42pm
davidbrown
United States
yeah xenon and halogen cannot be compared side by side.
Land rover aftermarket parts.
Post #130624 Wed Aug 08 2007 8:12am
