![]() | Home > Maintenance & Modifications > Roof Rails/Rack |
From memory, I think the "permanent" part of the roof rail system is only the holes that are left in the roof trim when you fit the rails. You can remove the rails as they are simply screwed in and plug the holes with rubber grommets for when it rains. Roof racks used to be common topic on here a long while ago - don't remember anyone talking about them recently. |
Look at your RRS and if your black roof strip has little grommits on it (3 on each side) you attach the roof rails through these holes if not you will have to drill your own or get some new ones from LR. 2005 Zambezi TDV6 - Gone but not forgotten
How much do they charge for these new holes? ![]() ![]() 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Ian.Richardson Member Since: 12 Feb 2007 Location: UK Posts: 101 ![]() ![]() |
Thanks for the response.
Yes! LR originally made you drill holes until they realised that they should supply them pre drilled! 2005 Zambezi TDV6 - Gone but not forgotten
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Well probably quite expensive, being LR, but they come with a 2 years warranty...... ![]() |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
I belive that the holes were pre-drills from the '07 model onward. Before, holes needed to be drill. Range Rover Vogue ‘17 TDV6
Correct.... |
I have pre drilled holes. Incredible advance in technology.
Maybe you could timeshare them with your friends, colleagues and neighbours |
No I think I will frame them and add it it my growing collection of raoof racks for various cars. |
