Home > Maintenance & Modifications > Roof Rails/Rack
Ian.Richardson
Roof Rails/Rack
Off to sunny North Wales soon on holiday. I can't risk having to leave the clubs behind so - am thinkinh abou getting some roof rails or a rack so that I can take my roof box.
Any thoughts oir advice would be appreciated.
I saw somone recently added the roof rack but I don't want this on all the time.
Post #126656 Thu Jul 19 2007 12:20pm
From memory, I think the "permanent" part of the roof rail system is only the holes that are left in the roof trim when you fit the rails. You can remove the rails as they are simply screwed in and plug the holes with rubber grommets for when it rains. Roof racks used to be common topic on here a long while ago - don't remember anyone talking about them recently.
Post #126657 Thu Jul 19 2007 12:30pm
Look at your RRS and if your black roof strip has little grommits on it (3 on each side) you attach the roof rails through these holes if not you will have to drill your own or get some new ones from LR. 2005 Zambezi TDV6 - Gone but not forgotten
Post #126659 Thu Jul 19 2007 12:33pm
How much do they charge for these new holes? Whistle
Post #126665 Thu Jul 19 2007 1:01pm
Ian.Richardson
Thanks for the response.
Is it just me or does it seem a bit odd to have to drill holes in any case to add roof rails to a car.
Post #126668 Thu Jul 19 2007 1:34pm
Yes! LR originally made you drill holes until they realised that they should supply them pre drilled! 2005 Zambezi TDV6 - Gone but not forgotten
Post #126669 Thu Jul 19 2007 1:36pm
flydive
Well probably quite expensive, being LR, but they come with a 2 years warranty...... Smile
Post #126670 Thu Jul 19 2007 1:37pm
Jimmy_75000
I belive that the holes were pre-drills from the '07 model onward. Before, holes needed to be drill. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #126905 Fri Jul 20 2007 8:46am
Correct.... Very Happy
Post #126906 Fri Jul 20 2007 8:47am
Ian.Richardson
I have pre drilled holes. Incredible advance in technology.
I just got a roof rail set on ebay from Marshells, which worked out about £40 less than from my local dealer.
Still cost £290 which is alot for something I will only use a couple of weeks a year.
Post #127698 Tue Jul 24 2007 2:45pm
Maybe you could timeshare them with your friends, colleagues and neighbours Wink
Post #127853 Wed Jul 25 2007 9:51am
Ian.Richardson
No I think I will frame them and add it it my growing collection of raoof racks for various cars.
Post #127855 Wed Jul 25 2007 9:53am
