![]() | Home > Technical > Sirius Radio |
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 ![]() ![]() ![]() |
My Sirius comes in great at recent temps of 0 F. Very quick 'lock' after backing out of the garage, and no 'drop-outs'. You must still have a defective antenna or some other connection needs attn.
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
What did they really fix or replace? Are you sure they really did something? |
USAGivGrn Member Since: 26 Nov 2005 Location: Omaha Posts: 24 ![]() ![]() ![]() |
Well, I am not sure they replaced anything but they kept it two weeks and said they did. I called them again, of course, and they said they would research it further and bring in back in. In the meantime, we are having a heat wave. I have been able to narrow the temp at which it switches off to aprox 37. It is sort of an amusing problem as well as frustrating. |
Finally, my Sirius Radio is repaired. To re-cap, it had intermittant failures which appeared to be related to sub-freezing temperatures. Antenna replacement did not repair it, but now a replacement of the module has solved the problem. Unfortunately, our very warm winter impeded repair since it was difficult to appreciate a problem with temperatures above 32 degrees. It was cold today, and I had great reception. |
So, they replaced the actual Sirius module? Anyway, finally! |
Yes the sirius module. I had to call sirius with a different esn number to get connected. |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
Please forgive my ignorance, but what is Sirius ? Is it specific to the U.S.?
It is a Satellite Radio with multiple channels of uncensored programing. I think it is only in USA and Canada, but I am not sure. It is an option on US RRS. |
