Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
Stickied and FAQ'd for ease of reference
Fri Jul 06 2007 8:42am |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
likely? do we know that? the biggest reported problem on rrsport for sure, but I think its clear its a setup/parts tolerance etc problem and not a parts/design problem as mine makes no noise at all |
Fri Jul 06 2007 7:29pm |
Darren Member Since: 17 May 2007 Location: Weybridge Posts: 13 |
Mine has this knock thru the ARC system also. Still in dealer, they have changed the steering column and have also shown me the LR bullitin regarding knocking thru the dynamic response and have said that it is normal. There is no fix as this is how it works apparently. The noise is the hydralic valves. The bullitin states at 20 mph rock the steering and a knock will be heard left to right. |
Tue Jul 10 2007 8:35pm |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 |
Darren: May I respectfully suggest that you need to spend more time reading through the various posts on this subject - these have been collated above. Land Rover and some of their dealers try to persuade customers the knocking is a "characteristic of the vehicle" but quite a few people on this forum consider that the noise is unacceptable and see the "characteristic of the vehicle" bulletin as an excuse on Land Rover's part for not finding a solution to what they consider is a fault with their vehicle. Insist your dealer submits an Electronic Product Quality Report or EPQ Report to Land Rover. The more dissatisfied owners who do this, the sooner we shall see some action on Land Rover's part to find a solution. |
Tue Jul 10 2007 10:26pm |
The following is a quoted from an earlier post by Nutty Nige and contains a test to positively identify whether the Dynamic Response 'KNOCKING FAULT' is present in your RRSport or whether a different fault is the cause of the knocking.
Thu Jul 12 2007 10:59am |
rodsport Member Since: 15 Jul 2007 Location: East Asia Posts: 7 |
I have a 2006 MY SC registered a month ago - I noticed this problem at low speed and was v concerned (as the same system had problems sending a water pipe type tapping through the brake pedal on delivery, which necessitated a software update).
Sun Jul 15 2007 1:53pm |
if it were a charateristic of the car then mine should have the knock too - but it doesn't - said this before but it sounds like an assembly or components tolerance issue to me |
Sun Jul 15 2007 2:59pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Kaine,
Mon Jul 16 2007 8:07am |
Guys - this thread should be joined by the admin police to the other (larger) one on the same topic - despite all this/these emails/qns there is no answer/realistic response from the manufacturer...................
Sat Jul 21 2007 5:06pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Burn them ALL and in doing so liberate yourselfs from the knock...
Sat Jul 21 2007 10:06pm |
Peter Member Since: 28 Feb 2006 Location: Maidenhead Posts: 175 |
Must be time for direct action!
Thu Aug 23 2007 9:16am |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
If your DR has been disconnected or the fuse has blown you will get a warning light on the drivers binnacle.
Thu Aug 23 2007 1:07pm |
I do drive my RRS hard on occasions.
Fri Aug 24 2007 6:55am |
Sun Member Since: 29 Aug 2007 Location: London Posts: 8 |
I am new to the forum, and have recently placed my order for RRS TDV8 HSE which I have been promised will arrive by end of September !
Thu Aug 30 2007 1:23pm |
