Home > Tips & Tricks > Nokia and Parrot (maybe others)
flydive
As I said in another thread, my Nokia N80 would not synchronize the phonebook with the Parrot 3100, I had to transfer it manually.
Found this on a Parrot forum, installed the Nokia software and it seems to work fine.
Might work for PTI users as well, who knows.
How to synchronise my phonebook with a Symbian Nokia phone ?
Symbian phones don't have automatic phonebook synchronization initially. You have to install Nokia 810 contact download on your phone.
First of all, please follow this link : http://europe.nokia.com/nokia/0,6771,42796,00.html
To install the Nokia synchronization software, please follow these steps :
* Please pair your phone to the car kit and switch off your engine.
* Launch the bluetooth manager that is provided with the Bluetooth Dongle's software.
* Find all the bluetooth devices and select your phone.
* Use the OBEX FILE TRANSFER feature of your phone.
* Define a Bluetooth PIN code.
* A window will appear on your phone, enter the same bluetooth PIN code.
* Send The software you have downloaded to your phone. Don't forget to accept the file transfer on your phone.
* You will receive a message on your phone. Open it and follow the instructions. Wait until the download is finished.
* If the installation is succesful you should find an icon with a car and a computer.
Once you have installed the specific software on your phone :
* Please make sure your phone is paired to the car kit.
* Switch off your car kit.
* On your phone go to the MENU screen.
* Select the software you have installed : the icon with a car and a computer.
* Select the OPTIONS command.
* Select OPEN command.
* Select the OPTIONS command again.
* Then switch on your engine.
* Wait until the car kit tell you the end of the synchronization.
* You can now assign voice tags. Refer to the voice commands menu.
* Note : If your phone doesn't appear in the list, then the relative version isn't available. Please be patient, it will likely be soon released.
Post #121024 Wed Jun 27 2007 1:44pm
NZHereIam
New Zealand 2006 Range Rover Sport TDV6 HSE Zermatt Silver
I have a Parrot kit in my Audi, I loaded the SW on N95 and it works perfectly, each time it connects to the Parrot, it downloads any changes.
It does not however, work in the RRS If you dont live on the EDGE, you are taking up too much space!!!!!!!!!!!!!
06 RRS HSE ( in Wellington Dockyard, still waiting for release!!)
05 Jeep Cherokee LTD Edition
Post #121031 Wed Jun 27 2007 2:17pm
