![]() | Home > General > Rev limiter |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
Envoy - TDv8 - Rev Limiter ?
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
Well if it was Smarticus, then it made the engine in my car misfire |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
and what speed did this happen at mate ? |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Why not lock it in low ratio and 1st gear? This should get the rev limiter working without your photo appearing in the local constabulary's most wanted. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 ![]() ![]() |
The rev limiter in my van is set really low |
Cheers mlines i never thought of trying it in low range 1st gear, will it hold it in first gear or will it change up gear automatically ???
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Eh up big boy The rev limiter in the P 38 is more severe because it shuts the injectors off so is quite sharp There is one on the Diesel you have -but it should really upshift to the next gear before you hit it but it would feel strange. The limiter you are thinking of in top gear is the speed limiter - this just stops it accelerating and holds it at 130mph - slightly different as there is no strange feeling with this one. As for your 70 mph -well you only have 2 speeds, on of off the pedal, so if anyone was going to hit the limiter I would have bet on you ![]() ![]() 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
I thought if you put it in low ratio and manual gear mode and change down to first then it would stay in first - otherwise steep off-road hill descents would become interesting if it decided to change up just when the going gets tough.
Martin i suppose you are quite right about the low gear and down hill, but isnt that what hill decent is for |
Sorry Martin yes it should. I was misleading you - I meant normal driving you cant hit it. - Unless your Envoy of course. ![]() ![]() ![]() If you hold it in first or second command shift you should feel it. Sounds like E needs a trip to the squeeler Were you doing 130 or there abouts Envoy ? You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
Nige you have PM some of my Previous cars
Of course you could put it in neutral or park, EPB on and sit on your drive and revs the nuts off it until the limiter cuts in........................... no risk of setting of any speed cameras or upsetting the locals then! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 ![]() ![]() ![]() |
Mine just stopped getting any quicker @ 135 mph very smooth.
