Home > Technical > Engine Fault Light On
Should Know Better
Hi - Apart from the obvious answer "take it to a dealer" which I am shortly about to do - is there any way to reset the light on a RRS S/C - or at read the "diagnostic trouble code" ?
Mine has the little orange engine light on but no other symptoms. I suspect it may be linked to the O2 sensor issues reported on here but is there any way I can find out before it heads in to the dealership?
Post #118517 Tue Jun 19 2007 9:47am
Take it to a dealer Whistle
Post #118520 Tue Jun 19 2007 9:52am
Should Know Better
Mmm.... Why didn't I think of that .... Laughing
Post #118527 Tue Jun 19 2007 10:04am
Tim in Scotland
You may already have done this but:_
Page 99 of the manual says that for petrol engines "Check Engine - Amber, acts as a bulb and sytem check when the starter switch turned on and extinguishes as soon as the engine is started. Illunimation at any other time indicates an engine fault. If the indicator illuminates continuously while driving, the emission performance of the engine management system is impaired - seek qualified assistance. If the indicator flashes while driving immediately reduce the engine power to avoid catalytic converter damage."
Do you also get a small "i" in the info display? If so then scroll the display to see what is there and then go to P86-95 of the manual for more info.
I think you've got the message already about the dealer! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #118532 Tue Jun 19 2007 10:25am
Should Know Better
Thanks for that - I had read the manual hence not "too" concerned about the cause, the light doesn't flash and there is no loss of power and the vehicle doesn't go into "limp home mode". I'm pretty sure there isn't an "i" but I'll go and and have another look to make sure!
I've just called my dealer who said drop it in tomorrow! - I was expecting them to be booked up for at least a week.
I'll post their answer when I get it back Thursday / Friday
Post #118533 Tue Jun 19 2007 10:31am
Tim in Scotland
The dealer may have taken it so quickly in case it is safety related.......................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #118534 Tue Jun 19 2007 10:32am
Actually a mate of mine's Golf has been reporting engine mgt troubles and the dealer won't actually give it back until it's sorted... seems they view the problem as dangerous.
Post #118556 Tue Jun 19 2007 11:45am
Should Know Better
Mmm - I'll let you know what they say
Post #118557 Tue Jun 19 2007 12:05pm
Should Know Better
All done, the culprit being a Lambda sensor apparently.
Post #119752 Fri Jun 22 2007 11:21am
Glad to hear you car is now sensing all it's lambdas Wink
Seriously - glad it all got sorted. Dodgy O2 sensors used to be a continuing problem on the E46 M3 too, if I remember.
Post #119754 Fri Jun 22 2007 11:27am
Should Know Better
Maybe it was making the engine run too rich and therefore explains the 14mpg I've been getting? Wink ... Or then again maybe that's just down to the readings from the throttle position sensor ...
Post #119756 Fri Jun 22 2007 11:39am
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Thats right S they were
Also 90% of other vehicle MIL lights on are the 02 sensor
Problem is their dirty environment doesn't help. If they could be stripped and cleaned it would save an immense amonut of warranty costs.
Mind you the Japanese are more reliable at it (what a surprise) Smile You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #119761 Fri Jun 22 2007 11:54am
