Home > Technical > Engine Fault Light On |
Should Know Better Member Since: 04 Jun 2007 Location: Essex Posts: 20 |
Hi - Apart from the obvious answer "take it to a dealer" which I am shortly about to do - is there any way to reset the light on a RRS S/C - or at read the "diagnostic trouble code" ?
Tue Jun 19 2007 9:47am |
Take it to a dealer
Tue Jun 19 2007 9:52am |
Mmm.... Why didn't I think of that .... |
Tue Jun 19 2007 10:04am |
Thanks for that - I had read the manual hence not "too" concerned about the cause, the light doesn't flash and there is no loss of power and the vehicle doesn't go into "limp home mode". I'm pretty sure there isn't an "i" but I'll go and and have another look to make sure!
Tue Jun 19 2007 10:31am |
The dealer may have taken it so quickly in case it is safety related.......................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Jun 19 2007 10:32am |
Actually a mate of mine's Golf has been reporting engine mgt troubles and the dealer won't actually give it back until it's sorted... seems they view the problem as dangerous.
Tue Jun 19 2007 11:45am |
Mmm - I'll let you know what they say |
Tue Jun 19 2007 12:05pm |
All done, the culprit being a Lambda sensor apparently. |
Fri Jun 22 2007 11:21am |
Glad to hear you car is now sensing all it's lambdas
Fri Jun 22 2007 11:27am |
Maybe it was making the engine run too rich and therefore explains the 14mpg I've been getting? ... Or then again maybe that's just down to the readings from the throttle position sensor ... |
Fri Jun 22 2007 11:39am |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 |
Thats right S they were
Fri Jun 22 2007 11:54am |
