![]() | Home > General > LIMP MODE? |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
Nutty Nige is yer man to answer that, just give him chance to awake from his Sunday afternoon slumber |
ALEX2575 Member Since: 18 Nov 2006 Location: London Posts: 30 ![]() ![]() ![]() |
Hi martin, i had this problem early on in the life of mine, after about 150 miles, it was due to a defective turbo in my case, and the engine mangement kicking in to restrict power. had to bring it back to dealers for a new turbo. mite be worth checking it in for a service in case you do any real damage by continuing to drive. 2.7 TDV6 HSE 2007 finnally arrived |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Oh sorry Envoy just woke up from Sunday |
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 ![]() |
For God's sake DON'T spray aerostart. |
marttin Member Since: 01 Jun 2007 Location: derry Posts: 10 ![]() ![]() ![]() |
hi cheers for the advice
Well the easiest way would be start at the air filter and follow the intake path all the way to the manifold.
ive tried taking the car up slowly and it goes pass the limp mode... meaning above 40mph...
its not something real daft like a blocked tank breather, try it with the fuel cap off, just a thought some of my Previous cars
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Personally if you are worried about a warranty issue because of wrong fuel use....then I would take it to a LR independant specialist first for evaluation and advice.OK they'll charge you for their time but isn't it worth it |
